R50/53 R53 Engine Health: Compression and Leakdown Test Results
Old Jan 6, 2019 | 11:54 AM
dieseldogpi's Avatar
dieseldogpi
Hey Everyone,
I picked up a parts car with a decent engine to swap into my 2004 MCS project. Donor car is a 2002 MCS hardtop with 121K on it. After getting it to run (bad starter and seized alternator) I wanted to test the health of the engine to see if it was good enough to do some preventative maintenance and pop it into the other car.
Compression test:
  • Cylinder 1: 150 PSI
  • Cylinder 2: 150 PSI
  • Cylinder 3: 150 PSI
  • Cylinder 4: 160 PSI
So from a compression test perspective it seems like its a healthy enough engine so I did a leakdown test. Full disclosure my leakdown tester is a cheap one from amazon. I am a little reluctant to believe the %'s as it would not stay calibrated. All cylinders had about 40-45% leakage. Which is not great. There were no bubbles in the coolant, so no head gasket issues. I heard very little air from the intake and exhaust so maybe some slight issue there. Mostly I heard air escaping from the dip stick...so there is definitely some air getting around the rings. My question is, with the compression being as decent as it is, and the cylinder leakage being consistent (plus the fact that my leakdown tester is inaccurate), is this engine healthy enough to throw it in another car and get a couple of thousand miles out of it? I'm sure I'll be burning some oil, but this is not my daily and I also have the original engine from my project that I was going to build in the mean time. Thoughts? Thanks!
Old Jan 6, 2019 | 01:55 PM
Minidogger's Avatar
Minidogger
Edit - roll of the dice, you can buy a lot of oil for cost of a rebuild.
Old Jan 7, 2019 | 12:56 PM
Hecka's Avatar
Hecka
Could be your PCV is blocked up. You can test if it's good by taking off the oil fill cap and then putting the opening of a latex glove over the oil fill opening. Turn the car on and if it eventually starts deflating the glove, you don't have an issue there. If it's constantly inflating the glove, buy a PCV for ~$30 and replace it in 2 minutes, then do your test again.
Old Jan 7, 2019 | 01:13 PM
dieseldogpi
Cool, thanks for the idea. I'll check that tonight.
Old Jan 7, 2019 | 04:27 PM
Tgriffithjr's Avatar
Tgriffithjr
Did you do the leak down with oil in the cylinders or dry? Makes a difference. Also did you verify that air is not leaking past the valves. If your swapping the engine I would at least have the head rebuilt.
CantComplain
Jan 21, 2018 09:04 PM
ginimini
Jul 23, 2015 03:34 PM
sho1sho1
Oct 30, 2013 08:17 AM
NC TRACKRAT
Dec 9, 2011 12:45 PM
jimz68
Oct 15, 2010 12:24 PM
