R55 misfiring, won't start
Old Oct 17, 2018 | 11:00 AM
Monk Edsel's Avatar
Monk Edsel
Hi every one... I don't use my car very often, and after a week of it being parked I drove it to go to the store today.
I was a few blocks away from home when the car started misfiring rather badly. If the car was up to speed it was okay, but when idling it would be rough. After stopping at a red light I hit the throttle, and the engine stopped completely after a period of about 5 sluggish seconds. I was able to wrench the wheel and push it into a parking spot with some help.
These are the codes the car is throwing. It is also showing a new error related to one of the DSC wheel sensors, but I assume that is completely unrelated.
Engine / Motor
Fault Code: 00296D
Fault Explanation: DFES DTCM.DFC EpmCaSO1OfsErr C - exhaust camshaft
Fault Code: 002783
Fault Explanation: DFES DTCM.DFC MDnpl C - misfire, several cylinders
Fault Code: 002773
Fault Explanation: DFES DTCM.DFC MD00npl C - Misfiring, Cylinder 1
Fault Code: 002777
Fault Explanation: DFES DTCM.DFC MD01npl C - Misfiring, Cylinder 3
Fault Code: 00277B
Fault Explanation: DFES DTCM.DFC MD02npl C - misfire, cylinder 4
Fault Code: 00277F
Fault Explanation: DFES DTCM.DFC MD03npl C - Misfiring, Cylinder 2
Fault Code: 002781
Fault Explanation: DFES DTCM.DFC MDmax C - misfire, several cylinders
Fault Code: 002771
Fault Explanation: DFES DTCM.DFC MD00max C - Misfiring, Cylinder 1
Fault Code: 002775
Fault Explanation: DFES DTCM.DFC MD01max C - Misfiring, Cylinder 3
Fault Code: 002779
Fault Explanation: DFES DTCM.DFC MD02max C - misfire, cylinder 4
The engine sounds like it is turning over very slowly when I try to start it, but it won't actually start. I ended up pushing it to a more secure location, and I tried to start it a last time. It sounded stronger then, but it still would not start. I am currently planning to return in a few hours and seeing if it will start then.
If any one has some insight on this, I'd appreciate it. Thanks so much.
Old Oct 17, 2018 | 11:14 AM
MiniToBe's Avatar
MiniToBe
what year is it, is it a justa or an S and how many miles?
I dont think you should try starting it just yet. open the valve cover and take a look to make sure all is good. also, how good is the oil level?
Old Oct 17, 2018 | 02:06 PM
Monk Edsel's Avatar
Monk Edsel
It's Justa 2010. I added a quart of Castrol the last time I drove it. I think the oil was changed around 3,000 miles ago, and this is the first time it has been topped off. It was down to the low mark on the dipstick after driving it a bit, so I added one quart per the manual.
Before I added the oil, the throttle had started to sometimes bog when the car was accelerating from a stop. It would take a few seconds for it to "unstick." Then it would be normal. It only happened a few times, maybe three, over the course of two days. After I added the oil, the car seemed happy again. Then I parked it, and have not driven it until today.
Initially, I thought the rough idle was due to a bad cylinder coil on cylinder 2. But a bad coil could not cause this...? I tried changing the coil anyway and of course there is no difference.
Right now the car is still a few blocks away, so I can't look at anything else at the moment. But I am having the car brought back tomorrow, so I will be able to see then.
It occurred to me that maybe the engine is not getting enough fuel? I cleaned the air filter a few months ago, and the battery and alternator seem okay. It is a high-mileage car, over 166k. The battery seems original, but I didn't get any low voltage warnings when I read the codes today.
Last edited by Monk Edsel; Oct 17, 2018 at 02:12 PM. Reason: Added mileage, autocorrect
grueinthebox
May 25, 2019 10:46 AM
spatulatr0n
R55 :: Clubman Talk (2008+)
Mar 17, 2017 01:21 PM
Sean_1
Electrical
Dec 16, 2013 07:40 AM
BETOGTI
Jan 28, 2012 06:17 AM
