R50/53 Remote Buttons Fix
Old Oct 17, 2018 | 03:53 AM
wildwilly2004's Avatar
wildwilly2004
Remote Buttons Fix
So I bought my son an 04 R50. Both remotes/keys that came with the car had destroyed, missing buttons (The outer button, not the little ones attached to the circuit board). So I bought the replacement shells on ebay hoping to be able to use them. Well, the quality is not there and it will require drilling of new remote shell to install pin which I can do, but decided to go a different route for the time being. Here is what I did.......I cut a small piece of handy wrap and put it in the button hole. I spread it flat with a toothpick and fished it between the plastic of the shell and the circuit board. (This was to protect the board and the button for the next step.) I then filled the hole with black shoe goo from Amazon
found here
Amazon Amazon
I smoothed it out, wiped off the extra I got around the perimeter and left it to dry.
Well, it looks just fine and I just tried the remote and it works great. I will see how long this lasts, but it is a simple quick, cheap DIY fix. I am sorry I can not post a pic. I would be happy to text you one if you PM me. I hope this helps someone. The one remote I have has a missing button in the circuit board. The remotes I bought actually came with 2 of these (LOOSE) in each remote. I do not have the proper soldering iron and solder for such small intricate work.....I might buy one or take it to someone with skills to do the tiny stuff.
Old Oct 17, 2018 | 07:49 PM
valvashon's Avatar
valvashon
I run MINI Key Hospital specifically for keys like yours! I'd love to see a couple of picture of the shells you bought and which seller you purchased them from- and a couple of pictures of the keys themselves. Send me an e-mail- "minikeyhospital@outlook.com". Most keys can be fixed for right around $50 or so. look forward to hearing from you!
Old Oct 18, 2018 | 04:38 AM
wildwilly2004
I will send you some pics at some point today.
Old Oct 18, 2018 | 04:41 AM
wildwilly2004
https://www.ebay.com/itm/182121137084
These are the ones I bought. Pics are on the way. Let me know if you got them. They were sent from my gmail.
Old Oct 18, 2018 | 01:58 PM
wildwilly2004
Let me know if you got the pics.
Old Oct 20, 2018 | 05:20 AM
wildwilly2004
Soldered new button on to other remote circuit board. Covered in handy-wrap and put it back together. Filled holes with shoe goo. Both remotes work just fine. The replacement buttons that came with the new shells were a little smaller than the oem's, but they worked just fine. Will see how long they last .....The may need to go to the Hospital soon enough if the home remedy does not hold.
Mini_Chan
Dec 23, 2019 02:25 PM
martmanvan
Mar 29, 2018 05:26 AM
11mcsaz
Nov 8, 2012 10:02 AM
ericfreeman
Nov 3, 2010 01:29 AM
not-so-rednwhitecooper
Electrical
Feb 14, 2009 12:14 PM
