Low power engine fault
Old Sep 1, 2018 | 01:49 PM
Coffee Bean's Avatar
Coffee Bean
I am receiving a low power fault on my 2p12 mini. It showed up after I washed the car. What could be the cause. I'm thinking the turbo picked up moisture when I started the car. What do you think
Old Sep 1, 2018 | 08:19 PM
MrGrumpy's Avatar
MrGrumpy
Well it’s basically you general “limp-mode” where the ECU basically bypasses the turbo in an effort to prevent engine damage, there’s more to it, but that’s the basic version. Your problem is that there any number of reasons that the car could be doing this, and there is really no way anybody can help you without more information. You need to get the codes read. That will help to point to what’s causing the issue. You can go to AutoZone to get them read, but they cannot read all of them. As an example, when I was having an issue before I bought a scan tool, I took my R60 to AutoZone to have the codes read while the car was actively in limp-mode. Their scanner showed no codes at all. But when I took it to a shop, it showed 5 codes that AutoZone couldn’t read. There are some codes that need specific BMW software to read. A mechanic that works on Mini and BMW should be able to read them, or scan tools are available to buy, or get them read somewhere.
After you get the codes, post them up here, and folks will be able to help from there.
Good luck
Old Oct 27, 2018 | 12:03 PM
Coffee Bean
Good luck
it was a cracked turbo hose that goes to the intake. It was cracked right at the connection and was ducking air and moisture.. the fault showed up after I washed the car and it apparently pulled some moisture in during that time.
Old Oct 27, 2018 | 01:33 PM
MrGrumpy's Avatar
MrGrumpy
Glad you got it figured out
jygong
R60/R61 Stock Problems/Issues
Dec 11, 2017 08:54 AM
Mayfair
Nov 30, 2016 10:20 AM
mohdghattas
Sep 28, 2014 05:19 PM
Inked469
May 20, 2014 10:02 AM
peckerhead
May 2, 2014 10:28 PM
