Check engine light
Old Aug 23, 2018 | 03:41 PM
Somp's Avatar
Somp
Check engine light
Hello. Check Engine light is on but OBD2 reader says no codes. Searching for codes while ignition is on and engine isn't running. Is that the correct procedure? Borrowed a second scanner and got the same "DTC 00" value. Anyone ever experience this? Model: Clubman, Year: 2009, OBD2 code reader $20 Performance Tech from Pepboys (maybe this scanner is a known problem for Mini's?). Thanks.
Old Aug 23, 2018 | 05:38 PM
jglover's Avatar
jglover
I believe your procedure is correct. I have a bmw specific scanner and sometimes there are codes "pending" that have given me a check engine light.
I dont want to say find a better scanner, but...............
Old Aug 23, 2018 | 05:50 PM
AZdsrt's Avatar
AZdsrt
Yep, bet your scanner can't pull bmw/mini specific codes. Common problem..
ggrimm01
Electrical
15
Apr 17, 2023 06:09 AM
TJ
Jun 25, 2017 02:09 PM
DanTheMan88
May 1, 2017 11:01 AM
donjulio
Mar 2, 2011 07:07 PM
