Navigation & Audio Mini Cooper F56 won't read changes to USB music
Old Aug 5, 2018 | 07:05 AM
rpcv's Avatar
rpcv
Question Mini Cooper F56 won't read changes to USB music
Hi, I just got a 2015 Mini F56 (without the Mini Connect). I put all my music on a USB, plugged it into the car and it seemed to find and play the music well.
After seeing how the car read the music files on the USB, I then put my USB back in my computer to clean up the files (deleted some I didn't want, refiled others under different folders, etc).
Putting the USB back in the Mini it doesn't recognize any of the changes, it still pulls up the original files and folders, even the ones that are no longer there.
How can I "reset" the USB in the Mini so it pulls what is currently on the drive?
THANK YOU!
Old Aug 5, 2018 | 08:18 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
What format is the USB stick? I'd probably reformat it and put the music back and see what happens. USB's are pretty cheap, try another one and see if that triggers a change. I've had no issues with mine at this point.
Old Aug 6, 2018 | 10:03 AM
rpcv's Avatar
rpcv
Smile Fixed it!
Thanks for the response. I discovered that just changing the name of the USB stick fixed the issue. I guess it stores info by the name so every time I want to add or change the music on my stick I will just need to update the name, which is very quick and easy to do.
LarriB
11
Apr 23, 2012 06:55 AM
John Felix
Feb 4, 2010 05:22 PM
ururk
Jul 19, 2005 07:13 AM
