R52 Selling R52 LotSC (99 of 100) $8,000 O.B.O
Old Jul 30, 2018 | 08:18 AM
benbalo's Avatar
benbalo
Hi guys,
So long story short a year and a half I bought this mini and since then I've been taking really good care of it and also having a blast!
Due to my work I'm moving abroad and it's way to expensive to take the car with me, so I'm selling it.
Since I appreciatte all the support and information that you guys share in NAM I think it will be nice to post it here first in case someone is interested.
These are some of the pictures I took you can see more in the link.
2008 Mini Cooper S JCW 99 of 100 LOTSC
Here's the detail of the maintenance and upgrades done in the last year.
(I bought pretty much all parts from ECS Tunning and a few from other NAM members).
August 2017
Oil and Filter Maintenance
Antifreeze Change
Brake Fluid Change
LH & RH Inner Axle Boots Change
September 2017
JCW Air Filter
Fuel Filter
Cabin Air Filter
October 2017
Belt Tensioner
Belt
Upper Engine Mount
Upper Engine Mount Bushing (Superpro)
Lower Engine Bushing Kit (Powerflex))
November 2017
JCW Spark Plugs (NGK Spark Plug High Power)
Ignition Coil Pack
Ignition Wire Set (NGK Performance Set)
March 2018
Mini Fini Sportlink (Bicyle Rack and Receiver Hitch)
April 2018
FRT Struts (Bilstein B4)
FRT Strut Bump Stop
FRT Strut Mount
Dust Boot
RR Struts (Bilstein B4)
RR Shock Mount
Jacking points Lifting Pads
Rear Fog Light
June 2018
Oil Pan Gasket
Crank Sensor O Ring
Thermostat Housing
Mishimoto Racing Thermostat
Supercharger Inlet Profile Gasket
Supercharger Outlet Profile Gasket
Driver Side Manifold to Horn Inlet Gasket
Shut Off Valve Profile Gasket
Waterpump (Gates)
FRT Drilled/Slotted JCW Brake Rotors
Rear EBC Ultimax Rotors
EBC Ultimax Premium Brake Pads
Brake Pad Sensors
Front Control Arm Bushings (Powerflex)
LH & RH Ball Joint
LH & RH Outer Ball Joint
July 2018
Crankshaft Rear Main Seal
Valve Cover Gasket Set
Timing Chain Guide Rail
Timing Chain Tensioner Guide Rail
Timing Chain Tensioner Screw Plug w/Gasket
Single Mass Flywheel Conversion Kit (Valeo)
Transmission Mount Bushings Buffer
Gearbox Bushing Set (Superpro)
Oil & Filter Service
A/C Condenser & Drier (Nissens)
If someone is interested just PM me.
Thanks!
Old Jul 30, 2018 | 06:49 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Post it in the Marketplace??????
Old Jul 30, 2018 | 07:04 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
In real estate, it is location, location, and location. In used car, it is mileage, mileage, and mileage.
Actually history of ownership is very important. e.g. You cannot reverse oxidation of the sheet metal. So you took very good care of it for 1 1/2 years. What about the rest of it life? Missing these crucial information, and tiny photos I doubt any serious buyer will bother.
Old Aug 1, 2018 | 11:50 AM
benbalo's Avatar
benbalo
Yes, I will add more photos and a video as well.
Moss Motors
Dec 29, 2011 12:38 PM
dpilgrim
157
Nov 3, 2010 01:39 PM
OasisT
Jul 22, 2007 01:29 AM
ponder
Dec 21, 2006 11:13 AM
Rocketboy_X
17
Nov 7, 2002 11:07 AM
