I pulled the trigger, Enkei VR5's. Good deal? Will these fit?
Old Jun 29, 2018 | 03:59 PM
copajoe's Avatar
copajoe
Tire rack does not have them in stock but found them and gave me a better price than anywhere I could find. Will be delivered in 10 days or so considering the 4th is next week. They also included the center ring, lug tool and 20 lug bolts for the rims. All at 150 each.
I should add they do hit you for 90 for shipping but all in all, still over $100 less than anywhere else I could find.
Here is the order:
REQUIRED CENTERING RING
4 In Stock N/C N/C
LUG INSTALLATION TOOL
1 In Stock N/C N/C
18X8 5-112 ET45 ENKEI VR5#
4 Out of Stock $149.00 $596.00
REQUIRED LUGBOLT FOR VEHICLE
20 In Stock N/C N/C
I got them from a guy named Todd at Tirerack but he said to wait until we can confirm fitment on the vehicle before we start dancing.
They are 18 x 8, 5x112 with an ET45. They should work, shouldn't they?
what is the best tire size for this? 215 40 18 or 215 35 18? anyone squeeze 225s on? I do not plan to lower the car. It will stay stock....
btw - I have a 2014 MCS 2 door hardtop.
here is the rim, photos on the car to come....
Attached Thumbnails I pulled the trigger, Enkei VR5's.  Good deal? Will these fit?-5spoke.jpg
Old Jun 29, 2018 | 10:39 PM
copajoe's Avatar
copajoe
anyone?
beuller????
Old Jul 7, 2018 | 05:54 AM
contented's Avatar
contented
Since you've already ordered them, just wait till they come and test fit one w/o a tire. That will tell you a lot. If you're ok at that point, then mount one tire and test fit again.
If they haven't arrived yet and you want a head start, do this - with the existing wheels on your car, crawl under and measure clearance to struts, springs, etc. Then pull a wheel and measure the wheel width, backspace, etc and calculate your offset. Now you have a baseline to compare your new wheels to. You'll quickly be able to tell where the backside of the new wheel is compared to existing and if you'll have any problems. Step two of the process is tire fitting. I stick w/ stock tire sizes and only a slightly lowered suspension. Minimizes problems.
Good luck
Old Jul 10, 2018 | 09:54 AM
Racinrav's Avatar
Racinrav
Hi Buddy,
I just added some BBS but 17' with the same 5x112 and ET 45 with 225-45-17 and it fits fine with not rub or graze. But mine are 17's. My car is a 2015 F56 Base with stock height. Good luck with the new wheels.
Old Jul 10, 2018 | 04:20 PM
copajoe's Avatar
copajoe
Originally Posted by Racinrav
Hi Buddy,
great. glad to hear it. how about a photo or two?
also, what size width did you go with? 7.5 or 8'?
Old Jul 10, 2018 | 04:44 PM
Racinrav's Avatar
Racinrav
i got 17x7.5. Here are some pics.
Old Jul 10, 2018 | 06:10 PM
copajoe's Avatar
copajoe
I like those rims!!!!
almost went for those myself.
you got crazy clearance between your tires and wheel wells. even mine with the stock rims have less than yours!
Old Jul 11, 2018 | 07:39 AM
6FT6's Avatar
6FT6
SPARCO TROFEO 5 GOLD RIMS 18 x 8 OFFSET 45mm, BACKSPACING 6.30", BOLT PATTERN 5-112 W/ MICHELIN PILOT SPORT 205/40ZR18
These are installed on my lowered 2018 MCS, no rubbing whatsoever. You may be fine with 225 tires once you don’t lower your ride height.
Old Jul 11, 2018 | 09:09 AM
copajoe's Avatar
copajoe
why only 205's? are these considered "stretched" on an 8" rim?
how about a down the line shot of those?
thanks for posting
Old Jul 11, 2018 | 11:32 AM
6FT6's Avatar
6FT6
thanks for posting
Here you go.
Old Jul 11, 2018 | 02:23 PM
Racinrav's Avatar
Racinrav
Thanks love the look of the BBS over the stock 15's. Yeah I was surprised at the space I had also. But now I wanna drop the car a little But would prob go with the safe 205-45-17 If I were to drop the mini.
Old Jul 12, 2018 | 09:04 PM
copajoe's Avatar
copajoe
mine are on back order found out today they wont show up for another 10 days.
im getting itchy for em!!!!
Old Jul 26, 2018 | 07:52 PM
copajoe's Avatar
copajoe
Finally showed up and had them installed today.
18x8 Enkei VR5's with 225 40 18 Continental Extreme Contact tires.
I have experienced no rubbing at all but my buddy at MINI of SD is going to get under it tomorrow to confirm the clearances all the way around. May look into a drop (if possible) but the ECU tune is next....
Old Aug 6, 2018 | 08:41 PM
easter's Avatar
easter
meaty tires are the best. did your buddy find any issues?
Old Aug 6, 2018 | 09:56 PM
copajoe's Avatar
copajoe
No issues
Clearance is tight but they clear with no rubbing. Hit some hard corners and some pretty good bumps in the road. All good.....
Old Aug 24, 2018 | 06:32 AM
R53hyperblue's Avatar
R53hyperblue
Do u think will clear the JCW calipers/brakes? I am very interested in buy the same wheels
hope u can help me
Old Aug 24, 2018 | 11:11 AM
copajoe's Avatar
copajoe
Yes
Honestly I cannot be certain but the is a LOT of room above the stock brakes that lead me to believe the brembos would work no problem.
remember, if you go, test for one prior to mounting just to be sure!
Old Aug 24, 2018 | 11:16 AM
R53hyperblue
Hi Coppajoe, thank you so much!!!
That will help me, also this model is also identical as the Enkei Kojin, right ??
http://enkei.com/shop/tuning/kojin/
Old Aug 24, 2018 | 11:24 AM
copajoe's Avatar
copajoe
No idea
good luck
Old Aug 24, 2018 | 11:28 AM
R53hyperblue
ok only last question, do u think could fit a tire 205/40/18 in that wheel ?
Old Aug 24, 2018 | 11:31 AM
copajoe's Avatar
copajoe
Probably
But it would be stretched and i do not think it would look good at all. Minimum go 215 or shrink the width to 7, 7.5 max.
ok. I'm out.
Old Aug 29, 2018 | 09:05 AM
6FT6's Avatar
6FT6
Look at my previous post with pics of 205s on an 8” rim. You decide. My car was customized at the mini dealership, they decided on the 205s and I haven’t had any issues (note it’s also lowered with KWs v1 coilovers).
Old Aug 29, 2018 | 11:06 AM
R53hyperblue
Thank you so much for your reply 6FT6!
I dont know what size if 215,225 or 235, I have a friend with a F56 JCW with exactly the same wheels that I will install, but he in 17" and mine 18x8.
He has 235/45/17 and looks awesome, what do u think ?
Old Aug 29, 2018 | 11:44 AM
6FT6's Avatar
6FT6
That looks boss! Do you plan on lowering? If not I don’t see why you can’t run with wider width tires, go with 225.
I may do a test fit of 215 and see how it runs.
Old Aug 29, 2018 | 11:48 AM
R53hyperblue
My friend has 235 and looks incredible hehehe, but I have little fear because he has wheels 17" and mine will be 18", I think 225 will be great for me. =)
