FS:: 2007 Mini cooper S r56, 139k, SoCal
Old Apr 24, 2018 | 10:07 PM
tkenupp's Avatar
tkenupp
Year: 2007
Model: Hardtop
Price: $4000
Mileage: 139
Color: Laser Blue
Location (Region): SoCAl
Hi!
I'm selling my Clean Title 2007 R56 that has been my daily since december.
What i did on the car at 130k when i bought it:
Oil change - Liqui Moly 5w30 and Liqui moly ceratec
Walnut Blasting
NGK Laser iridium sparkplugs
Coils
OEM Pierburg Diverter valve
Craven speed oil Dipstick
Full paint detail and applied manzerna powerlock.
At 138k:
Drilled brake discs with ceramic brake pads and dot 4 lv Brake fluid.
Oil filter housing gasket and upgraded detroit turbo oil feed line
Timming chain was done at 100.XXX
I'm doing an oil change with new filter on every 3k miles.
The cons
Oil leak on valve cover
Oil leak on crank seal(passagenger side)
Map thermostat problem( ordered from Mini of San francisco and i will giving away the part with the car with proof of purchase and 24k warranty).
Despite the oil leaks i used to check all the fluids every morning and run a proprietary bmw scanner, btw i'll be giving the scanner with the car too.
The reason what i'm selling it is because i have a another project car that is consuming too much money and i need something more economical.
I'm in Santa Clarita, CA.
Thank you!
Old Apr 24, 2018 | 10:40 PM
vetsvette's Avatar
vetsvette
Moderator
I believe I have a Lightning Blue hood scoop laying around in my storage building if you need one.
Old Apr 24, 2018 | 10:41 PM
tkenupp's Avatar
tkenupp
Hi there! I believe the color is laser blue metallic. Do you have pics? How much for the hood scoop?
Old Apr 24, 2018 | 10:46 PM
vetsvette's Avatar
vetsvette
Moderator
Well, Lightning Blue will be a little darker. Just have a picture when it was on my old '07.
Old Apr 24, 2018 | 11:20 PM
tkenupp's Avatar
tkenupp
I see.. how much for the scoop?
Old Apr 24, 2018 | 11:31 PM
vetsvette's Avatar
vetsvette
Moderator
If I can lay my hands on it... how about $75 shipped.
modir93
Mar 24, 2015 12:18 PM
wikedgolf
Southern California
35
Sep 10, 2007 03:27 PM
wikedgolf
Aug 15, 2007 04:23 PM
wikedgolf
Jun 22, 2007 02:42 PM
