Suspension TSW Springs and LCW
Old Mar 23, 2018 | 02:19 AM
tag1260's Avatar
tag1260
TSW Springs and LCW
Do you need to change the LCAs when using the TSW springs? They only lower about the same as the JCW springs, from what I've read, and they(JCW) use they stock LCA's. Don't want to eat up tires. Thanks
Old Mar 23, 2018 | 03:26 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
From my tease arch, you don’t “Have” to get adjustable arms, but if you want to get better alignment numbers you should. Even with a little bit of lowering, you will end up with about 2 degrees camber in the rear. Seems like you want between 1-1.5 in the rear, and 1.5-2 in the front to get the best out of the suspension in the Mini.
Old Mar 23, 2018 | 04:29 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Pretty sure the JCW springs are a 10 mm drop where Way's TSW are 20 mm.
Don't know too much about that newer fangled Gen2 but they may have the adjustable RCA that the facelift Gen1s have.
Old Mar 23, 2018 | 06:49 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
There is some adjustment in the lower control arm, but only about ±0.5°. The aftermarket arms allow for ±4°.
Old Mar 24, 2018 | 04:11 PM
mbwicz's Avatar
mbwicz
The drop will not affect camber a tremendous amount. You won’t tear up your tires driving to the alignment shop. Get it on a machine and see what the numbers are. See the least amount of camber your tech can get, if you are less than -2.0, you should be fine. As stated above -1.5 may be ideal. I’ve seen some people need LCA, others don’t. One way to find out.
Don’t forget to trim your bumpstops. You want at least 1-1/4 in of bump travel in the rear before you hit the bump stops, or you will regret the change.
Have fun,
Mike
minintrigue
Mar 3, 2015 09:50 AM
minimarks
Suspension
38
Aug 6, 2014 10:34 PM
dwf137
Suspension
69
Jul 20, 2009 03:12 PM
tr6drvr
Suspension
Oct 21, 2008 05:57 PM
