R56 Grinding noise when starting with brake pressed down
I just bought a used 2012 mini Cooper S (6 speed manual, 90k miles) and noticed that if I have the brake pedal pressed down when i start the engine, it make a short grinding noise. Doesn't do it every time.... Maybe 30% of the time.
Should I be concerned about that? What might the cause be?
Never had that issue before but it seems like others have. Check out this link and I'm sure you can find more in the forums.
https://www.northamericanmotoring.co...-start-up.html
I saw that post and didn't think it was quite the same as my issue. The grinding only happens when the brake is pressed. And so far, it only happens for a half a second, and not every time.
jacobsen1
Jun 4, 2011 09:29 AM
Steve in SLO
Mar 17, 2008 04:39 AM
ficcion
Feb 4, 2008 08:00 PM
