Interior/Exterior Adding power folding mirrors
Old Dec 11, 2017 | 04:52 PM
CooperT's Avatar
CooperT
Tried searching for the part number for the power folding mirrors and switch but not having much luck. Anyone have a site for searching for parts to retrofit? I tried realoem, but didn't find any thing.
Thanks,
Tim
Old Dec 11, 2017 | 04:56 PM
vetsvette's Avatar
vetsvette
Moderator
Part numbers are shown here.
http://www.realoem.com/bmw/enUS/show...diagId=51_9574
Old Dec 11, 2017 | 04:59 PM
CooperT's Avatar
CooperT
Figures, found something shortly after posting...
Think these will work.
51167401098
51167401097
Can anyone verify?
Old Dec 11, 2017 | 05:01 PM
CooperT's Avatar
CooperT
Thanks! That's what I found also. You know how that happens and makes you feel sheepish... 😀
Originally Posted by vetsvette
Old Dec 11, 2017 | 05:05 PM
CooperT's Avatar
CooperT
Now to find the switch. That seems to be a little more elusive.
Old Dec 11, 2017 | 05:08 PM
CooperT's Avatar
CooperT
Think I found it also...
61319354861
OK, nothing to see here, carry on. ��
http://www.realoem.com/bmw/enUS/show...03#61319354861
Last edited by CooperT; Dec 12, 2017 at 05:21 AM. Reason: Link to door switch panel if anyone else is interested...
Old Dec 11, 2017 | 05:48 PM
Mini_Vinnie's Avatar
Mini_Vinnie
Moderator
61319354861
I found
8675309
which also happens to be Jennys number too
I'll see myself out, thank you
Old Dec 11, 2017 | 07:09 PM
CooperT's Avatar
CooperT
Weisenheimer! 😉
Originally Posted by Mini_Vinnie
I found
8675309
Old Dec 11, 2017 | 07:48 PM
vetsvette's Avatar
vetsvette
Moderator
Oh what the heck. Here comes a little more thread drift.
Old Dec 11, 2017 | 11:22 PM
Mini_Vinnie
Moderator
https://youtu.be/6WTdTwcmxyo
im pretty good at doing that
Old Dec 12, 2017 | 05:44 AM
CooperT's Avatar
CooperT
You guys are as bad as Abbott and Costello! Or Penn and Teller! Tom and Jerry?
Anyway, a couple of more questions on this if anyone has anything other than Itchy and Scratchy here. :-D
Found a good price difference in mirrors. One says Genuine Mini ($375), the other Genuine BMW ($272), both the same part #. I assume that means they are interchangeable? https://www.ecstuning.com/Search/Sit...h/51167401098/
Old Dec 12, 2017 | 01:33 PM
TVPostSound's Avatar
TVPostSound
BMW no longer available.
You know ECS reds these posts!!!
Old Dec 12, 2017 | 02:09 PM
It was a duplicate error on the site, the BMW price was wrong. It's a Genuine MINI only part. If you see them let me know.
" 8675309 " Not a Genuine MINI part but could be only the manufacturer part number... https://www.ecstuning.com/Search/SiteSearch/8675309/ ... no luck there
Old Dec 12, 2017 | 02:22 PM
TVPostSound
Its here on the bathroom wall:
Old Dec 12, 2017 | 02:30 PM
Yep forgot the dash, still no luck.
Old Dec 12, 2017 | 03:01 PM
CooperT's Avatar
CooperT
Maybe they changed the number.
Old Feb 23, 2018 | 09:27 AM
AndresR's Avatar
AndresR
Does anybody tryed this and worked fine? I just need to buy the power fold mirrors, switch and I'm done? Or I need to do some coding ?
Old May 19, 2018 | 08:30 AM
minicooperjp's Avatar
minicooperjp
The power folding mirrors have 3 pins and the normal have 5, so it would also be a matter of modifying the wire harness, which is something I have been trying to figure out.
Old Oct 3, 2018 | 04:57 AM
pillpusher84's Avatar
pillpusher84
Any luck? Interested in doing the same retrofit on my 2015 F55. Bought it used a few days ago, and it's missing this option. Don't really care other than the fact that without power folding, the vehicle will not tilt the passenger mirror when in reverse ... kind of annoying as all my otehr BMWs have this ... but the MINI doesn't ... so missing the function sorely when reversing in the MINI
Old Oct 3, 2018 | 07:20 AM
AndresR's Avatar
AndresR
I'm stuck too, I have the mirrors and the new switch buttons.
You can code the tilt with Carly app or Bimmersomething on your BMW's if it's an issue for you
Old Oct 3, 2018 | 09:43 AM
pillpusher84
i already use ESYS and have extensively coded the f55, however with the tilt already coded it isn’t working. I will go back and compare the coding from my f85 to the f55 to see if additional codes need to be changed beyond the standard, which is already coded.
Old Jun 19, 2020 | 09:14 AM
sam5terling's Avatar
sam5terling
2019 f55 s
Was anyone able to get this working? I am curious about buying the parts and installing, I have the little mini projector in my driver mirror so id assume the wiring is all there to do the power folding, just would hate to buy the parts install them and not be able to get them to work
Old Jun 19, 2020 | 09:55 AM
minicooperjp
Best thing to do would be removing a mirror to see how many pins it has and then removing the connect that goes to the driver switch where you control the mirrors, that way we can see what wiring is there.
I had the 5 pin one which is the manual folding and just had to make some modifications to make the power folding ones work!
Old Jun 19, 2020 | 10:35 AM
sam5terling
that’s super useful information thank you so much! I’ll check that out tonight. Just need the mirrors and the switch right? So long as the wiring is there. What modifications did you have to make?
Old Jun 19, 2020 | 11:20 AM
minicooperjp
That is correct! I had to cut 2 wires and solder them to other wires. It was not too bad!
