2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Would these fit???
Old Dec 4, 2017 | 10:40 PM
bluonyx's Avatar
bluonyx
Would these fit???
I can't stand the rims on the CM, they're just to black for me. I found these on eBay, so will they fit? Is 8.5" to wide?
https://www.ebay.com/itm/18-ALLOY-WHEELS-CRUIZE-GTO-GM-FIT-FOR-MINI-COOPER-COOPER-S2014/172968873874?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2060353.m1438.l2649
Old Dec 5, 2017 | 05:32 AM
MrFunk's Avatar
MrFunk
The add doesn't show what the hub size is of the wheels. So not sure. You will want something with a Center Bore: 66.6 mm - or you'll need an adapter to correct it which is fine. This will only work though if the CB of the new wheels is larger though. I'm not quite sure where to source adapters but I'm sure they can be found online.
The rest of the specs look fine.
Just my opinion - those wheels would look way better in a 19. 18's may not look as good...
Old Dec 5, 2017 | 06:10 AM
TheOriginalKonky's Avatar
TheOriginalKonky
hub-centric rings, not adapters
http://www.1010tires.com/Accessories...-Centric-Rings
Old Dec 5, 2017 | 08:54 AM
MrFunk's Avatar
MrFunk
^^ya ya! Lol
Old Dec 5, 2017 | 11:22 AM
Yep have to have conical fitment for the wheel bolts, 66.6 CB to match up otherwise you will need hub centric rings.
