Drivetrain Oil cooler - how have you routed the hoses ?
Old Dec 4, 2017 | 03:31 PM
Mr.Bourbon's Avatar
Mr.Bourbon
How have you routed your oil cooler hoses from take off plate to cooler ?
From take off plate along top of subframe to top of crash tube through bottom corner of rad shroud is possible. ( Tight to driveshaft and pulleys and doesn't leave space for thermostat.)
From take off plate, up over the top and down to the cooler in front of the radiator,( routing hoses that high - oil aeration, flow problems ?)
I've got brake ducts which may have to make way for the hoses.
Any advice welcome, thanks.
