F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 F54 Nav wiring for sub install
Old Nov 27, 2017 | 11:28 PM
tmusante's Avatar
tmusante
Hey everyone! Went thru the F54 threads and did not see anyone ask about the wiring in order to add a sub woofer to the Clubman. I have a plan to build and enclosure and have the new Navi system.
thanks in advance!
Old Nov 29, 2017 | 07:15 AM
2017All4's Avatar
2017All4
Super Moderator
There is some stuff about adding a sub on 3rd gen cars floating around. I'll see if I can find it.
Old Nov 29, 2017 | 07:19 AM
2017All4's Avatar
2017All4
Super Moderator
Start here:
https://www.northamericanmotoring.co...ml#post4278710
Try searching for f56 subwoofer. Not Clubman, but a start.
Old Nov 29, 2017 | 07:31 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Thought about it on my F56. Went instead with Bavsound Ghost underseat woofer up grade with a JL audio amp to replace the stock HK amp. More bass in the car than I need at the moment. It doesn't shake the car like a big Sub but it is very good.
Technic PNP https://technicpnp.com has some harnesses that make the wiring a simple swap for either a sub add on or what I did.
Old Nov 29, 2017 | 11:05 AM
tmusante's Avatar
tmusante
That might be the link! I want to install 2 10s in the trunk... working with the storage trunk... Hoping that I can cut into it and drop in 2 enclosures
Old Dec 3, 2017 | 11:08 AM
Pure Red's Avatar
Pure Red
For wiring, and repair manuals, I’m having good luck with newtis.info
