CV axle shaft removal
Old Nov 6, 2017 | 02:51 PM
JoeyBR60's Avatar
JoeyBR60
Hi,
Has anyone had experience removing the driveshaft / axleshafts from an R60 Countryman with All4?
I might need to remove the right hand front shaft if attempts to repair the thread are unsuccessful!
Im assuming I just need to pry it out of the box (it's already free from the wheel bearing hub assembly) but wanted to double check in case I do some damage!
Cheers
Joe
Old Dec 7, 2017 | 07:26 AM
bro_hof's Avatar
bro_hof
Once the halfshaft is free from the hub there is a half shaft support near where it goes into the transmisison that will also have to be removed. 4 bolts and it comes off but it's tight working quarters in there. To get the halfshaft out of the transmission I used a long screwdriver and tapped it with a hammer from under the car outward, not many great prying points under there.
Old Dec 7, 2017 | 07:53 AM
JoeyBR60's Avatar
JoeyBR60
Cheers dude.
I looked on RealOEM and noticed that supporting bracket so figured it needed to be unbolted.
In the end I was able to repair the thread on the shaft end with a meaty M22 x 1.5 die, and didnt need to replace the shaft thankfully.
