Interior/Exterior Gauge options for CS Mount F56
Old Oct 17, 2017 | 06:42 PM
djtomy's Avatar
djtomy
I just have the mount (60mm) installed right & now have to figure out what gauges look the best!
Anyone have recommendation's for gauges?
Craven Speed pod mount
Old Oct 17, 2017 | 07:05 PM
vetsvette's Avatar
vetsvette
Moderator
Did you check with CravenSpeed? I know they sell gauges to fit their pods.
Old Oct 18, 2017 | 09:42 AM
djtomy's Avatar
djtomy
I did see those, wasn't to impressed, but at $200.00 for just the 1 basic boost gauge, isn't right! plus installation hardware. Just wanted to see if someone has tried something that matches up to the OEM also. I also checked over to ECS. There are not many pics with gauges for our cars.
Edit: I think my best bet is with prosport 60mm
Old Oct 30, 2017 | 08:55 AM
ih8cornnuts's Avatar
ih8cornnuts
Check out Speedhut, you can customize the gauge font, color, needle, etc.
Old Nov 1, 2017 | 03:53 PM
Andrew Park's Avatar
Andrew Park
I'm running the Prosport Premium Series boost and oil temp gauge.
Old Nov 1, 2017 | 11:19 PM
djtomy's Avatar
djtomy
Wow those look great! 60mm or 52?
I did see those, but didn't know how they matched up!
They do quite well!
I think I will go that route.
Many thanks...
Old Nov 1, 2017 | 11:25 PM
Andrew Park
They do quite well!
Many thanks...
I have the 52mm but they do have 60mm also. The only problem is they run red all the time since wiring it to the headlight switch doesn't work because of the Mini using canbus.
Old Nov 3, 2017 | 02:03 PM
djtomy's Avatar
djtomy
Not a problem, I can deal with that.
I have the 60mm pods
Ill definitely go with a boost gauge...
I'm just not sure on the other one, which ever is easiest to install, suggestions?
And where did you get your hardware from?
Old Nov 3, 2017 | 02:08 PM
Andrew Park
The boost gauge is easy to install. You just need a boost tap. NM has a boost tap that taps into the manifold. The oil temp gauge I used the supplied NPT sensor and bought a oil drain plug that has a the hole for the sensor to go into. The hardest part is wiring everything up to the fuse box that is located near the passenger seat. Putting in these gauges are definitely not plug and play so hopefully you have some electrical knowledge.
Old Nov 3, 2017 | 02:25 PM
djtomy's Avatar
djtomy
Ok thanks, I do have some knowledge..
