Timing chain tensioner
So I measured my timing chain on my 2011 Countryman and it is at 66.8mm. Does anyone have the part number for the new replacement tensioner? I also pulled the valve cover all is good down there.
11317607551 This is the most common latest version but you really should check yourself on realoem.com You have not specified which Countryman or where you are in the world. 68+mm is the limit for complete replacement so well inside safe zone.
68mm is the tolerance using the measuring tool in place of the tensioner, tells you how stretched the chain is.
