R61 :: Paceman Talk R61 Cooper and Cooper S hatchback discussion NOT REPAIR RELATED Discussions.
R61 JCW Sport Brake Installation At A Non–German Bodyshop
Old Oct 3, 2017 | 10:39 AM
Greenbird555's Avatar
Greenbird555
Hi Everyone,
Is it ok to have a non–Mini/BMW shop to install the JCW sport brakes, or should I just go to a German shop instead?
I don’t mind either way.
Old Oct 3, 2017 | 01:04 PM
Just a shop that can follow an install guide. Most people that work on german or British cars should be able to figure out the MINI, not that hard. Most VW/audi shops could do it, just give them a heads up and do you have the install pdf?
Old Oct 3, 2017 | 08:36 PM
GPMini's Avatar
GPMini
There is nothing special about them. Any competent shop that can do brakes won't have a problem. I did my own last spring, it was quite simple, I was expecting it to be worse.
Old Oct 3, 2017 | 09:05 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
Agree with GPMini - I installed mine a couple of years ago. No big deal. You need to be prepared to bleed the brakes though, so have brake fluid on hand. A pressure bleeder is also a big help - check out ECS Tuning, I have their Schwaben brand bleeder.
If you're not up for DIY, then find an independent shop you trust.
Old Oct 25, 2017 | 09:16 PM
Greenbird555
@ECTuning no I do not have the PDF.
Link?
Old Oct 25, 2017 | 11:04 PM
squawSkiBum
Moderator
Greenbird555, what model and year? JCW brakes are different for Gen1 vs. Gen2 vs. Gen3.
Old Oct 26, 2017 | 05:35 AM
Derek86's Avatar
Derek86
Any shop should be able to do brake calipers... If they can't they should not be in business.
Old Oct 26, 2017 | 06:00 AM
Link?
Yes, what model do you have?
Old Oct 27, 2017 | 05:27 AM
Greenbird555
@ECSTuning 2015 Paceman S
Old Oct 27, 2017 | 06:15 AM
So the JCW Paceman Brakes added to a Pacman, simple easy swap. Top three kits on the page linked. That should be a straight swap, no big deal.
https://www.ecstuning.com/Mini-2015-Cooper_Paceman-R61-S-Hatchback-L4_1.6L_N18B16A/Braking/Performance/
