R56 MINI Cooper Base (Start-Up Issue)
Old Sep 28, 2017 | 02:07 PM
R56Rva's Avatar
R56Rva
2007 MINI Cooper - 212,000 Miles
Two days ago my MINI decided to die while I was driving.
Here’s what happened:
• MINI took a corner and as I accelerated it cut out and stalled.
• I proceeded to attempt to restart the car with no luck.
• The car cranked but didn’t start the engine.
• Day that it happened I was washing my car and got water into exhaust pipe on incline.
• Two days previous to that I had brought it to Crown Of MINI Richmond where they replaced my Water Pump and Vacuumed coolent.
Error Codes Given:
- P2177 - System Too Lean Off Idle
- P0030 - HO2S Hester Control Circut
- P0201 - Injector Circut/Open - Cylinder 1
and for All cylinders.
I checked the belt and fuses and they seemed to be fine.
Old Sep 28, 2017 | 04:05 PM
Jeffair10's Avatar
Jeffair10
Error Codes Given:
While I didn't get any of those codes, I did have the "shutdown while driving" and generally no restart. Sometimes it would start after a bit, but usually I had to get it towed. Turned out to be a failing ignition relay. The part was ~$19. I have a 2009 Mini Clubman S BTW.
