AC, Blower motor problems
I have a 2012 Countryman S All4. My AC have some squeaky noises, normally at low speeds. I was guessing the Blower motor, because everything work fine except the sound. Does anyone know where is the fan located? Is it hard to change by yourself? is it parts no. 64113422644 or 64119266899 (both looks like same)? should i stay with OEM parts or other after market brand?
I would check if there is a cabin air filter in your HVAC box, I've seen cars that someone is too cheap to replace the filter and they just dispose of the dirty one and run without a filter. If that's the case you may have leaves and some other fun stuff in the fan housing, but I have also seen blower motors develop a squeak over time, probably replaced 2 blower motors in the second gen cars over the years.
I would stick to stock if it was my car, unless it's a quality aftermarket name (OE aftermarket provider).
