FS:: 6 Speed S model with lots of mods
Year: 2004
Model: Hardtop
Price: $5500
Mileage: 161000
Color: Liquid Yellow
Location (Region): SoCAl
This is what he had done to the vehicle:
New:
cabin filter, battery, fuel filter, serpentine belt, spark plugs, steering rack, power steering hoses, p/s reservoir, motor mounts, tie rods, inner ball joints, belt tensioner, clutch slave cylinder, front and rear Mintex brake pads, front and rear ATE coated rotors, sensors, inner CV boots, fuel pump, Powerflex steering rack bushings, Powerflex front lower control arm bushings, torque solution engine mount, (he did a wheel alignment) trans oil changed at 151K with Redline MTL, oil change at 149K with Mobil 1 (0W40), Helix short shifter adapter, VIP 723 Engine stabilizer, One Ball exhaust, Detroit tuned bypass valve, M7 catch can, DDM air intake tube, DDM intercooler coupler, rear wiper delete, RACELAND coil overs, Bavarian Auto Sport shifter.
He installed HID's. He put 215's all around (tire size) rubs on a hard turn, nothing major.
I did the DDM Air box, new headliner, new left door mirror, coolant reservoir, thermostat and housing, temp sensor, other small misc. stuff (clips, bolts, screws, valve stem caps, etc, etc.) new Monte Carlo MOMO steering wheel and hub (not even a week old) ALL OE parts except for the obvious.
Has full tool kit, coil over wrenches, Mini 1st aid kit, Cooper belt tensioner tool, all stock parts, new clutch master never used, new a/c compressor clutch never used, recent oil change done by me (5W30), have new spark plugs but I haven't installed them. I will add an Ipod adapter as well. I'm sure there's more but this is all I can remember, I will add to the list if need be.
Car runs perfect. All fresh fluids, NO leaks, A/C and heater work fine, shifts smooth, sunroof opens and closes, shades are intact, windows open and close, stock radio, all dash components work. Interior is very clean except for the drivers seat, has some wear (tears on seat) no cracks on dash, door panels, no scuff marks. I've clayed and buffed the paint. It's not bad at all. Few scratches here and there, one ding on RT 1/4 panel. Harmon Kardon sound system sounds good. If you go over a hard bump ABS light comes on but goes off. No issues with ABS. All I need to do is buy the capacitors for air bag light and I'm done. I've invested time and money.
I did not choose the license plates he did and I kept them. Any other questions please send me a message. I will answer them as best I can. More pics, info? Just ask.
I can take the stickers off if you don't like them.
