More New Products from ECS & Partstoberfest Cooling Thermostat Sale!
ECS Tuning
N18 Engine Performance Module Tuner From NM Engineering NEW!
These boost controllers were designed from the beginning to be easily installed and even easier to use. It plugs into a sensor and uses the factory DME to re-map boost, timing, and fuel maps. Changes on the NM module can be done with a switch on the module itself.
Up to 28Hp 36lb/ft gain on NM Engineering module, making this respected MINI tuning brand a no-brainer.
A great leader in MINI performance parts, continuing in the Gen 3 MINI platform!
Go Faster!
Fits: N18 Engine
R55-R61 MINI Cooper S (2011-2016)
R55-R61 MINI Cooper JCW (2013-2016)
May work with the N14 engine and older Gen 2 MINIs also! Testing in progress!
Click HERE For your MINI N18 Engine Power Module
MINI Cooper Rear Wiper Delete Plug - Glass Version
You decided to drop the rear wiper for a clean look but aren't sure what to put in the hole it leaves behind. Homemade fixes made from bottle caps and super glue look... homemade.
We have the answer. Our rear wiper arm delete cover is an exact fit matte black trim plug with transparent sealing surround. Push it into the hole vacated by the wiper arm for a factory-like look that seals water tight. We have a kit that also contains the RTV silcone needed below for an easy complete install.
Simple and Clean
Fit:
R56 MINI Cooper /S/JCW '07-'13
Click HERE For ECS MINI Cooper wiper delete - glass version
aFe New Products!
Advanced FLOW engineering (aFe) is a manufacturer of automotive cold air intake systems, performance air filters, fluid filters, intake manifolds turbochargers, programmers, throttle body spacers and exhaust systems. aFe was founded in 1999 and is headquartered in Corona, California, USA.
Fits:
Your MINI
Click HERE For MINI Cooper
On Sale! Assembled By ECS Cooling Refresh R53 R52 S 15% off and free shipping
Don’t let an aging cooling system keep you from enjoying your MINI the way it was meant to be driven.
Proper function is maintained by regularly replacing coolant, housings, and hoses in order to prevent leaks or corrosion that cause overheating and dreaded head-gasket issues.
Make sure your cooling system is doing its job by performing the proper maintenance repairs with our assembled kits.
9/18-9/20 3 days only!
Fits:
R52/R53 MINI Cooper S/JCW (2002-2008)
Click HERE For Gen 1 MINI Cooper S/JCW
Partstoberfest - Cooling Kits Up To 15% OFF!
Sale ends 9/20/17
Fits:
R55-R59 MINI Cooper /S/JCW '07-'15
Go Faster!
Fits: N18 Engine
Simple and Clean
Fit:
aFe New Products!
Fits:
Your MINI
Fits:
Sale ends 9/20/17
Fits:
