Temp sensor vs Themostat
Old Sep 7, 2017 | 06:27 PM
SODA66's Avatar
SODA66
I have a 2011 Clubman NON -S. The yellow engine light came on , I noticed the coolant tank is low but have not noticed any leakage in my garage. If it possible its the temperature sensor or the thermostat. Car has 86,000 miles on it. Also, when you buy the whole thermostat housing does it come with a new temperature sensor.
Old Sep 7, 2017 | 06:41 PM
R56devotion's Avatar
R56devotion
Kits
ECS has a cooling kit for that. Sensor included in housing.
Old Sep 8, 2017 | 02:04 PM
yes, right here:
https://www.ecstuning.com/Mini-2011-...ngine/Cooling/
One and done kit.
Old Sep 12, 2017 | 09:13 AM
MiniToBe's Avatar
MiniToBe
most of them do come with the temp sensor. make sure you match the plugs otherwise you would need an additional wiring harness.
Old Sep 12, 2017 | 09:20 AM
R56devotion
Yes, the thermostat and sensor is included " pre installed" into the plastic housing. You will either see a small puddle on top of the transmission due to a warped or cracked housing, a leak at the rear coolant pipe above the oil pan on the rear of the block or an overflow bottle with a faulty cap or leak at the clipped on hose fitting on the bottom.
The pumps themselves can leak on the pass side. However in my experience, the coolant bottle is target #1, because it gets manipulated and moved overtime you change the oil.
A coolant pressure test is the fastest way towards resolution. But if its a car your going to keep - you may choose to go after these repairs proactively and give yourself some piece of mind before winter.
New coolant and make sure they bleed the system properly and that you have good heat inside the cabin after.
Old Sep 19, 2017 | 12:57 PM
^^+1
