New Products @ ECS
New Products @ ECS
ECS Tuning
ZippeeShade Now @ ECS with updated Catalog
ZippeeShade Sunroof Sunshades are developed exclusively to fit your MINI's sunroof. Newly redesigned with UV-resistant black fabric on one side and reflective silver on the other side. Once installed, you can simply leave the shade in place and open your sunroof without fear of it blowing away. Easy install.
Fits:
Your MINI
Click HERE For your MINI Parts
Dinan Dinantonic Elite New
This high-end controller was designed from the beginning to be easily installed and even easier to use. It plugs into a sensor and uses the factory DME to re-map boost, timing, and fuel maps. Changes can be made via Bluetooth, allowing you to use your smartphone to turn boost and other parameters up for max performance or down for conservative driving.
Fits:
Your MINI
Click HERE For Dinan Dinantronic Elite
Liqui-Moly Molygen Engine Oil 5w-40 ONLY AT ECS Tuning
• Lower fuel consumption, Longer engine life.
• Molecular friction control – 15% lower friction coefficient to reduce wear by up to 30%.
• Meets BMW/MINI LL-01
Fits:
Your MINI
Click HERE For MINI Cooper
Fits:
Your MINI
Fits:
Your MINI
Fits:
Your MINI
bump
Sold out of the new Molygen, but sign up for auto notify on the products and you will be emailed when it comes back in.
