R58 Oil pressure range
Old Aug 30, 2017 | 05:13 AM
mayfield1's Avatar
mayfield1
Oil pressure range
Just installed oil pressure gauge in my 2013 JCW Coupe and wondering what normal oil pressure range is for the N-18 engine.
Old Aug 30, 2017 | 06:01 PM
dube53's Avatar
dube53
I may be wrong but I believe you can also have oil pressure reading from the RPM display if you select the available options.
Old Oct 16, 2017 | 05:57 PM
Wmesq77's Avatar
Wmesq77
Glad to hear about your oil pressure gauge install - I have purchased an oil temp gauge and would like to know how and where, you connected the sending unit. A picture would be great.
Thanks,
Wmesq
Old Oct 17, 2017 | 02:38 PM
Capt_bj's Avatar
Capt_bj
ummmmmm ... don't think so ..... and even the SCANGAUGE can't do this one. It is not an OBDII item for monitoring and requires a 'physical' sensor someplace. The most common place for a GEN1 car was an adaptor between the oil pan and the bung, since the plug faced back - and you could then run a tube from the oil pan to the gauge. But with GEN2 cars the bung was on the bottom of the pan so this became a BAD option .... so the search for a new place began
I'm sure I'll be corrected if I'm wrong ....
Old Oct 27, 2017 | 07:23 AM
bugeye1031's Avatar
bugeye1031
Moderator
I'm pretty sure that Capt_BJ is correct (as usual). I have a CravenSpeed adapter, but haven't installed it yet.
https://www.cravenspeed.com/gauge-se...BoCtzsQAvD_BwE
Old Oct 29, 2017 | 08:22 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
Correct we do not have an oil pressure sensor, only a low oil pressure switch. Crave Speed makes an adapter for the oil pressure switch that you can use to attach sensors to.
https://www.cravenspeed.com/gauge-sender-adapters/
Old Jun 10, 2022 | 02:05 PM
DogfaceSGM's Avatar
DogfaceSGM
I know, I am resurrecting an old thread but, I have Bimmerlink installed on my phone and my Android head unit. I connected to the ODBII with a K+DCAN cable and to the USB of my of my head unit. In Bimmerlink you can setup a dashboard with different sensor values. One of the available ones was oil pressure. I set it up and it was working.
There must be something that is sending that data. I know Torque didn't bring it up when I used it to connect using a cheap ELM327 Bluetooth adapter. I haven't tried my Veepeak adapter to see if perhaps it does with it. Problem there is my head unit cannot see the VeePeak and I haven't been able to make Torque Pro work with the K+DCAN cable.
Just a curiosity note.
Old Jun 10, 2022 | 06:23 PM
Lou@Prototype-R's Avatar
Lou@Prototype-R
Vendor
The N18 does have a pressure sensor as opposed to the pressure switch in the N14. On the N18 the oil pressure is controlled by the DME based on temperature and rpm. A pressure sensor is required for that control to be closed loop..
Custom tuning solutions for BMW & Mini.
Old Jun 11, 2022 | 12:52 AM
kerwooddr's Avatar
kerwooddr
Veteran: Navy
I just installed the Cravenspeed oil pressure sensor on my N16 engine as part of their dual gauge installation kit, more to follow on that in my 2013 Coupe build thread elsewhere. Anyway, what I'm seeing is 21-25 psi at idle, 30-35 psi at cruise, and spikes up to 60 psi when stomping on it.
Old Jun 11, 2022 | 02:49 PM
DogfaceSGM's Avatar
DogfaceSGM
Similar values to what I see on my physical gauge.
I was just curious as had I been able to view it with the Torque App, I wouldn't have added the oil pressure and coolant temp gauges. Unfortunately, I didn't have Bimmerlink when I installed the gauges and it doesn't let you customize the dashboard like Torque.
Old Jul 21, 2022 | 03:44 PM
DogfaceSGM's Avatar
DogfaceSGM
BTW, there is a X-gauge that will read oil pressure on the N18 using a Scan Gauge II. I set it up but it and BimmerLink both report 14-15 PSI higher than my physical gauge. Interesting thing about it is it reads 14-15 PSI with the engine off power on so at least it is consistent.
Broke out my old Scan Gauge II to monitor boost and thought I would setup the oil pressure also.
Old Jul 22, 2022 | 03:35 AM
kerwooddr's Avatar
kerwooddr
Veteran: Navy
Hmm. Based on my reading, the oil pressure sensor for the N18 engine, OEM part number 12617592532, looks to be identical to the sensor the the N16 engine, with the same part number. So if the X-gauge Scan Gauge II add-on to read oil pressure is only specified to work on an N18 engine, something else must be different in the engine electronics from the N16 engine, as the sensor part is identical between the two.
Oil Pressure Switch for N16/N18 engine, OEM part #12617592532
For what it's worth, the oil pressure switch for the N12/N14 engines is a different beast, OEM part number 12617568481:
Oil Pressure Switch for N12/N14 engine, OEM Part #12617568481
A pressure switch is more of a binary device, measuring an on/off state, which makes sense if its function is to illuminate the oil pressure warning light if the oil pressure drops below a certain level. By contrast, and in this context, a pressure sensor is actually measuring a pressure differential between two points, say 0-100 psi (for example). So the fact that the same pressure sensor is used on the two engines could explain why the X-gauge Scan Gauge II could show an actual oil pressure reading if it's used on an N16 engine, despite it's being rated only for the N18 engine. Whether that oil pressure reading has any validity when the unit is used on an N16 engine is TBD.
mkov608
Jul 21, 2022 04:02 PM
rondayvous
Mar 2, 2019 07:04 PM
yellowbritishrocket
May 19, 2009 12:19 PM
timekpr
Jul 25, 2007 09:17 PM
fishbulb
Jan 8, 2006 02:30 PM
