Electrical Changing vin/miles on Kombi 3k91D with cas3 R270 programmer
Old Aug 30, 2017 | 04:23 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
anyone done it? I've got a nav kombi with a 3k91d chip I need to zero out the vin & miles
planning on doing this with an R270+
Old Aug 30, 2017 | 05:15 AM
MiniToBe's Avatar
MiniToBe
I havent dont it on kombi but i did it on CAS with R270. I am not sure if there is an option to change the vin through R270. but you can always use WinKfp to do so. is the chip part of the library in R270?
Old Aug 30, 2017 | 06:15 AM
MrBlah's Avatar
MrBlah
I do not think winkfp can change the vin on the ecu or kombi modules, it has to be done with a direct method like the r270
Old Aug 30, 2017 | 06:18 AM
MiniToBe's Avatar
MiniToBe
mmm...i did vin changing a dozen times using winkfp. the ECU/DME is a difference story.
Old Aug 30, 2017 | 06:44 AM
MrBlah's Avatar
MrBlah
on the kombi? It should be eprom vin locked just like the ECU for the same reason, to prevent mile rollbacks
Old Aug 30, 2017 | 06:55 AM
MiniToBe's Avatar
MiniToBe
yes the kombi. i never had to change the mileage but the vin, yes sure...many times.
Old Aug 30, 2017 | 07:48 AM
MrBlah's Avatar
MrBlah
I'll try it, right now my cluster shows I've only got 70k miles, the car has 110k miles on it
my understanding is if the vin is changed or set to FF it'll re-read the miles and set it to the highest module (ecu in my case)
Old Aug 30, 2017 | 07:51 AM
MiniToBe's Avatar
MiniToBe
So the mileage you want is 110k right?
dumb question, what happened to the original kombi?
Old Aug 30, 2017 | 08:28 AM
MrBlah's Avatar
MrBlah
Took out a crono center and put in a used nav center without the screen/radio, using a 7" datalogger for track inatead
Old Jun 9, 2018 | 10:20 PM
Andy Dao's Avatar
Andy Dao
Hi,
Were you able to change the VIN on the Navi unit?
