R50/53 Torque table 2005 mini Cooper S
Looking for a complete torque table for 2005 mini Cooper S I replace the steering rack and don't know what to torque the 22 mm banjo bolts to but I would like a complete table if possible will you respond thank you
From Bentley,
Steering pump stuff:
HP line to power steering pump 10 Nm 89 in-lb
Power steering pump bracket to rubber mount 8 Nm 71 in-lb
Power steering pump bracket to subframe 19 Nm 14 ft-lb (replace self locking fasteners)
Power steering pump to mounting bracket 10 Nm 89 in-lb
Steering rack stuff:
(replace sealing rings)
high pressure M14 banjo 34 nM 25 ft-lb
low pressure M16 banjo 40 Nm 30 ft lb
Heat shield to steering rack 8 Nm 6 ft-lb
lower steering shaft universal joint eccentric pinch bolt to steering rack shaft 22 Nm 16 ft-lb (replace M8 bolt and nut)
road wheel to hub 120 Nm 89 ft-lb
steering rack to subframe 56 Nm 41 ft-lb
Tie rod adjusting nut clamping ring 45 Nm 33 ft lb
tie rod end to steering knuckle 52 Nm 38 ft lb (replace self locking nut)
tie rod to steering rack 80 Nm 59 ft-lb
