rimS
Old Oct 11, 2004 | 03:06 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
rimS
Falken Wheel Circuit Spec (gun Metal)
PCD: 4x100
ET: 40
Weight: 22.5lbs.
HERE ARE THE WHEELS IM GOING TO BE PURCHASING SOON WILL THEY FIR , IM NOT GONG TO LOWER WAT DO YOU GUYS THINK?
littlehandegan
Fit**
Old Oct 11, 2004 | 04:55 PM
petecrosby's Avatar
petecrosby
They'll fit but don't use anything bigger than 205/45-R17 tires or you will get some rubbing in the rearm expecially of you use lowering springs. The rubbing is minor with the 215/45-R17s, though, with stock springs.
Old Oct 12, 2004 | 02:46 PM
littlehandegan
off set?
my stock offset is 42mm those wheels are 40mm wat does this mean? Will i be able to tell a diffrence in how it looks will it poke out more or be farther up under the wheel wells?
Old Oct 12, 2004 | 03:06 PM
miniraider's Avatar
miniraider
they should fit.
post pictures when you get them on...
Old Oct 12, 2004 | 03:37 PM
meanboy's Avatar
meanboy
Yup, ours rubs on occassion with passengers.
Old Oct 12, 2004 | 05:52 PM
littlehandegan
mean boy do you have lowering springs?wat tires are u yousing? im using the stock runflats 205/45-R17,
Doc Pain
Mar 10, 2021 04:50 AM
freeman727
Dec 10, 2017 04:00 AM
luisfv56
Nov 16, 2015 01:55 PM
malibujoey
Nov 9, 2015 08:22 PM
Winston46
Nov 9, 2015 06:18 AM
