205/50 on SSR Comp 15x6"
Old Oct 11, 2004 | 05:45 AM
gbuff1's Avatar
gbuff1
I want to get a set of these wheels for open track/DEs; I know the tires will fit on the 6" rims but will I have more sidewall flex than with a 6.5 or 7"? I'm trying to keep the weight down as much as possible. What's the best width?
Thanks.
Old Oct 11, 2004 | 08:20 AM
Alex@tirerack's Avatar
Alex@tirerack
Thanks.
7.0 imho
Alex
Old Oct 11, 2004 | 09:49 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Thanks.
205/50-15 tires will fit on rims as narrow as 15x5.5" but it is not ideal. Everything is a compromise of weight vs fitment and contact patch. For the best traction in your case you might want to consider 15x7" rims with 225/45-15 tires. If you want to use 205/50-15 tires (you have them already) then 15x7" would be recommended. The added weight of the wider rim is offset by the better fit/contact patch.
Kimolaoha
Dec 5, 2020 09:32 PM
ej
Feb 20, 2016 02:16 PM
Keet
SCCA Solo and ProSolo
Sep 20, 2015 01:02 PM
Keet
Sep 19, 2015 09:45 PM
offroadratfabricator
Sep 6, 2015 09:54 AM
