2006 R 50 rear sunroof drain
Quick question..
Where can you access the rear drain tubes so I can " blow" them clean like the FRONT tubes.
They were clogged...put the pressure gun on......and running like a shower !!!
Would like to do to the rear ones as well....
Appreciate any and all help.
Thank you
Thank you
Not sure if it's good to blow them out in reverse, but the rear drains exit in the top corners of the hatch opening. You'll see the black plastic drains up between the hinges and hatch struts.
While you're at it, you might want to clamp all 4 drain tubes on the sunroof with small hose clamps. The drain tubes slip off easily and cause all kinds of problems, especially the passenger front tube which ends up leaking on the BMC causing a bunch of electrical issues. It's a common problem for them to fall off over time. Sometimes they come off from blowing the drains out during cleaning.
Here's some info on the front tubes:
https://www.northamericanmotoring.co...-footwell.html
There was another recent post on how to secure the rear tubes. I'll post a link if I find it.
