R52 Looking at 06 mcs convertible today
Old Jul 11, 2017 | 01:05 PM
Bryce Aston's Avatar
Bryce Aston
What are the major things I need to look at or listen for..? 83k for miles. 6 speed. Silver with black top.
Thanks in adv
Bryce
Old Jul 11, 2017 | 02:40 PM
Whine not Walnuts's Avatar
Whine not Walnuts
At those miles the usual suspect items would be: crank sensor o-ring, water pump, t-stat, t-stat cover, belt, belt tensioner, struts, front end suspension bushings, and all the fluids. You should also verify that the low speed fan runs when the AC is switched on.
For the top, you should open and check to see if the glides on the targa/moon roof are dry (bad) or if they have some grease (good) on them. Chances are that the rubber trim at the back of the top where it meets the trunk is cracked. There are threads in the DIY on a simple fix for the trim.
Old Jul 11, 2017 | 05:33 PM
Bryce Aston
Checked it out tonight. 2nd owner. Paperwork for oil changes, cam gear change ($2200)???, $4700 left front collision repair for a deer strike.... Has an LSD. Few Nicks and dents and scuffs. Clear coat coming off rims. Car is very tight up front. Pulls nicely up through gears. New tires because old ones where scalloped.....what would cause that? In my mind the deer strike front end damage bent something.... Original timing chain and power steeeing.
Decisions. They wanted $7500. Offered 5500.
Old Jul 12, 2017 | 05:14 AM
Bryce Aston
Here is the VIN decided....
VIN
WMWRH33566TJ42320Type codeRH33TypeCOOPER S (USA)E seriesR52 ()SeriesMTypeCABRIOSteeringLLDoors2EngineW11Displa cement1.60Power125DriveFRONTTransmissionMECHColour DARK SILVER METALLIC (871)UpholsteryLEDER GRAVITY/PANTHER SCHWARZ (T6PN)Prod.date2006-07-27CodeDescription (interface)Description (EPC)S1CAASELEKTION COP RELEVANTER FAHRZEUGESelection of COP relevant vehiclesS210ADYNAMISCHE STAB. CONTROL (DSC)Dynamic stability controlS249AMULTIFUNKTION FUER LENKRADMultifunction f steering wheelS2REALM R. WEB SPOKE, 2-TEILIG/NOTLAUF.MINI LA wheel Web spoke flat-runn. prop.S2TAASPERRDIFERENTIALDifferential lock 25%S314AFRONTSCHEIBENWASCHDUESEN BEHEIZTDoor mirror / driver's lock, heatedS329AMOTORHAUBENSTREIFEN SCHWARZHood stripe, blackS345ACHROME LINE INTERIEURChrome Line InterieurS405AVERCHROMTE AUSSENSPIEGELKAPPENMirror shrouds in chromeS429AINTERIEUR-OBERFLAECHE ANTHRAZITInterior surface, anthraciteS450ABEIFAHRERSITZ HOEHENVERSTELLUNGHeight adjustment, passenger seatS473AARMAUFLAGE VORNArmrest frontS494ASITZHEIZUNG FUER FAHRER/BEIFAHRERSeat heating driver/passengerS520ANEBELSCHEINWERFERFog lightsS522AXENON-LICHTXenon LightCodeDescription (interface)Description (EPC)S534AKLIMAAUTOMATIKAutomatic air conditioningS550ABORDCOMPUTEROn-board computerS5AAANEBELSCHLUSSLEUCHTERear fog lightS645ARADIO-STEUERUNG USBMW US RadioS650ACD-LAUFWERKCD playerS674AHIFI-SYSTEM HARMAN/KARDONHi-Fi System Harman KardonS692ACD WECHSLER I-BUS VORBEREITUNGPreparation, BMW 6-CD changer I-busS895AZUSATZLUEFTERAdditional fanS8SPACOP STEUERUNGControl unit COPS925AVERSANDSCHUTZPAKETDummy-SALAPACodeDescription (interface)Description (EPC)S226ASPORTLICHE FAHRWERKSABSTIMMUNGSports suspension settingsS255ASPORT-LEDERLENKRADSports leather steering wheelS441ARAUCHERPAKETSmoker packageS470AKINDERSITZBEFESTIGUNG ISOFIXIsofix-SystemS481ASPORTSITZE FUER FAHRER/BEIFAHRERSports seatS493AABLAGENPAKETStorage compartment packageS508APARK DISTANCE CONTROL (PDC)Park Distance Control (PDC)S546ADREHZAHLMESSERRevolution counterS563ALICHTPAKETLight packageS657ARADIO BOOSTRadio, BMW Business/MINI BoostS736A2. FUNKFERNBEDIENUNGSSCHLUESSEL2nd radio remote control keyS823AHEISSLAND-AUSFUEHRUNGHot-climate versionS845AAKUSTISCHE GURTWARNUNGAcoustic belt warningS853ASPRACHVERSION ENGLISCHLanguage version EnglishS876AFUNKFREQUENZ 315 MHZRadio frequency 315 MHzCodeDescription (interface)Description (EPC)S992ASTEUERUNG KENNZEICHENBEFESTIGUNGControl of number-plate attachment
Old Jul 12, 2017 | 07:04 AM
Big things, convertible top works and fully funtions, power steering works. Put the top up and down a couple times.
Old Jul 13, 2017 | 05:40 AM
Bryce Aston
Walked away from this car. Front end damage and the cam/bearing sleeve replacement raised red flags in my book. NEXT up
