Need help identifying this noise
Old Jun 27, 2017 | 08:56 PM
bansasn's Avatar
bansasn
Hello all,
04 MCS. Please help me identify this knocking/drum like noise coming from the passenger suspension side. You can hear the noise when on a level road and you can hear more on a bumpy road. Anyone have any ideas or experienced this with their MCS? I already changed both sides of the wheel bearing and CV axle.
Thanks in advance.
Old Jun 27, 2017 | 10:22 PM
Filmy's Avatar
Filmy
Check your lower (dogbone) motor mount. Beyond that, have a look at your LCA bushings - they're likely shot in any R53 (if they haven't already been replaced). Ball joints too, but that would be a really bad ball joint if it made that sound. Anything loose in your strut assembly(ies)?
Old Jun 28, 2017 | 05:42 AM
Minibeagle's Avatar
Minibeagle
I had a loose front strut top nut once that rattled quite a bit. No harm in checking that out.
Old Jun 28, 2017 | 10:34 AM
bansasn's Avatar
bansasn
Thank you! I will look into it.
Old Jul 6, 2017 | 01:13 PM
bansasn's Avatar
bansasn
I got the chance to look underneath and top of the Mini this past weekend. Look thoroughly and didn't find anything out of ordinary. Bushings and ball joints look ok. No major wear and tear just minor small leak driver side shock and passenger side pinion rack. Nothing to worry much about. Still need to keep an eye on. At the top although...this is what I found. Could this be the culprit that makes the odd drum noise?
Old Jul 6, 2017 | 01:44 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Just might be...It's on the right side. Regardless, that's not going to get better by itself!
