R55 Operating(driving) car without key fob
Old Jun 14, 2017 | 03:56 PM
bassix67's Avatar
bassix67
Hi, newbie here! I have a 2011 club S and last night I noticed after turning of my car for over an hour my transmission indicator and start button was still lit. I press the start button without the key and it started.
I woke up this morning and they were still lit and the car started I put it into drive and drove off without the key . I know it has the convience option and have used it before but this seems like something different. I will disconnect the battery to see if I resets. Any info or experience will be greatly appreciated!
Old Jun 15, 2017 | 07:52 PM
gjxj's Avatar
gjxj
I've discovered on my 2010 mcs you can deliberately (or perhaps accidentally?) put it into this mode. If you shut it down, remove the key, and while keeping your foot on the brake (and clutch) push "start" it fires back up keyless. After having done this it will stay "on" (dash lit up) when you shut it down. You need to push the button a second time to actually turn it off. Really weird and I puzzle over whether this serves some purpose, or is a bug in the system logic..
Old Jun 20, 2017 | 08:02 PM
schatzy62's Avatar
schatzy62
If it has the convenience option as you mention, and you have the key in your pocket/purse/sitting on the roof, the care will start. That is how it is designed to work.
To test this leave all keys at least 30 feet away from car and try and start it. it should not start.
Old Jun 23, 2017 | 08:27 PM
cargusjoh's Avatar
cargusjoh
I don't have the convenience package and verify the steps above worked on mine (11 R55). Thanks, interesting.
Old Jun 27, 2017 | 01:15 PM
schatzy62's Avatar
schatzy62
May also be called the Comfort Access Option. If you have Comfort Access option you should have little black buttons on the front door handles.
Old Jun 28, 2017 | 03:12 PM
bassix67's Avatar
bassix67
Thanks guys, Its part of the Comfort package. Helps to read the manual lol!!!
