FS:: Performance Tuners | Top Genuine & European Parts | 3D Design Japan
Old Jun 14, 2017 | 01:19 PM
ECS Tuning
MINI F54-F57 Performance Module Tuners
These boost controllers were designed from the beginning to be easily installed and even easier to use. It plugs into a sensor and uses the factory DME to re-map boost, timing, and fuel maps. Changes can be made via Bluetooth the Dinan, allowing you to use your smartphone to turn boost up for max performance or down for conservative driving. Changes on the NM module can be done with a switch on the module itself.
Up to 30Hp 40lb/ft gain on the Dinan or 44Hp 34lb/ft (on 100 octane) on the NM Engineering module.
Two great leaders in MINI performance parts, continuing in the Gen 3 MIN
Fits:
F54-F57 MINI Cooper /S/JCW 14'+
Click HERE For your MINI Cooper Options
MINI Euro Cubby Tray | R50 R52 R53
This snap-in storage cubby tray is a fast and easy way to add extra storage for small items to your MINI R50 R52 R53.
Straight from the Euro market, the unit comes in panther black to match the original dash panels. The grippy rubber tray liner helps keep small items from sliding around.
A spare rectangular hole in the panel accepts a stock switch so you can control any accessory you choose. Or, cover the hole with the blind plate included in the kit for a smooth appearance. Add even more storage room with the Euro Parcel Shelf.
Fits: Gen 1 MINI
R50 MINI Cooper (2002-2006)
R52 MINI Cooper Convertible / S / JCW (2005-2008)
R53 MINI Cooper S / JCW (2002-2006)
Click HERE For your Gen 1 MINI Cooper
Genuine MINI Products | R53 MINI Cooper S/JCW
You drive a MINI, and you're serious about the parts. We're talking Genuine, and when you need them, you don't have time to look around and play games. Look no further.
ECS Tuning has what you need. With a huge inventory of Genuine MINI parts, and a website loaded with information, we stock it all from the most common to the “hard to find”. You can order with confidence, knowing our experts will accurately pack and ship your order as quickly as possible.
Leave the hide and seek to the other guys. Let ECS Tuning get you the Genuine MINI parts you need. Now.
Fits:
R53 MINI Cooper S/JCW (2002-2006)
Click HERE For your R53 MINI Cooper Gen 1 Options
3D Design Components For Your MINI
3D Design is focused on high-quality styling components that allow you to personalize the look of your MINI.
Inspired by European tuning trends and Japan's unique VIP tuning style, their wide range of lips, diffusers, side skirts, and spoilers are made from high-quality urethane or super light, super strong prepreg dry carbon and install easily to your factory bumpers and skirts to offer an understated, aggressive performance look.
Set your MINI apart from the crowd with this wide variety of components from 3D Design, now available at ECS Tuning.
Fits:
R55 MINI Clubman S / JCW (2009-2010)
R56 MINI Cooper S / JCW (2007-2010)
R57 MINI Cooper Convertible S / JCW (2009-2010)
Click HERE For your 2007-2010 MINI Cooper Options
Fits:
R55 MINI Clubman S / JCW (2011+)
R56 MINI Cooper S / JCW (2011+)
R57 MINI Cooper Convertible S / JCW (2011+)
R58 MINI Coupe' S / JCW (2012+)
R59 MINI Roadster S / JCW (2012+)
Click HERE For your 2011+ MINI Cooper Options
