AC compressor
Old May 31, 2017 | 03:27 PM
siep3's Avatar
siep3
AC compressor
AC is not blowing cold. Manifold gauge shows the low side has 25psi and high side around 50psi.
I am leaning toward the AC compressor unless there is something I should be looking at.
I want to see how much it would cost to replace the AC compressor (labor only).
Old May 31, 2017 | 08:41 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I would first evac and recharge the system first and see if it's just low as those numbers are really low. If you are making any pressure the compressor is likely working
