F55/F56 2nd tank: 39 mpg!
Old May 3, 2017 | 06:27 PM
VelvetFoot's Avatar
VelvetFoot
2nd tank: 39 mpg!
Just got 39 mpg in my F55 3 banger. Interesting that the 39 calculated by the car matched actual miles/gallons pumped. Other cars I've had they're always 3 mpg optimistic.
Old May 4, 2017 | 01:09 PM
pkunk's Avatar
pkunk
My R55 has averaged 38mpg over the past 16k. One or 2 tanks is not an accurate assessment. I use an APP Gas Manager to keep track of all my vehicles. The free APP only allows for 10 entries each vehicle but when that is filled up I can email it to myself and save them as a PDF, then clear the entries and start over. @ vehicles run a shade over 20 mpg and the motorhome has averaged 8mpg even pulling the Mini!
Old May 4, 2017 | 02:17 PM
VelvetFoot's Avatar
VelvetFoot
Is it your existence that the mpg display in the MINI is as close as my experience?
Old May 4, 2017 | 03:32 PM
pkunk's Avatar
pkunk
No, but my speedo is off by about 3 mph high also. Optimistic MPG readouts make me smile, but then even the reality of 38mpg is smileworthy
Old May 10, 2017 | 06:57 AM
activehybrid's Avatar
activehybrid
I did 35.6 with one tank for mixed use (70% highway ) with my 17 Cooper S Auto
Old May 10, 2017 | 11:43 AM
hp79's Avatar
hp79
My record with 2015 F56 was about 45 mpg in pure highway at 65 mph cruising the whole gas tank.
For me, the trip computer is optimistic by 2-3 mpg most of the time but sometimes it's pretty close to what it is. Also, you need to consider that the gas tank being full when it rejects taking more gas at the pump might not actually mean it's full. The sensors on the gas nozzles might be different, or there could be some air bubbles trapped somewhere.
I use an app called Fuelly to log my miles. I don't know if it works offline, but it's free and all the data is stored in the web.
Old May 10, 2017 | 04:48 PM
VelvetFoot's Avatar
VelvetFoot
That's pretty good.
On another note on your cheat sheet:
"Disable showing blank line in BC"
Is that the blank line when you're cycling the display at the bottom of the speedometer? That would eliminate a button push, for sure.
and...
"Turn off radio/nav when opening drivers door
(you don't need to press ingnition twice when parking)"
I have found on my automatic that if I hit the on/off switch with my foot on the brake, and then open the door, the radio shuts down. Do you like it in your current setting? I can't see why you'd want to have the radio playing by default when leaving the car. If you wanted to let it play while you're washing it or something, you could turn it on then. So I can see making the change.
Old May 15, 2017 | 12:24 AM
hp79's Avatar
hp79
Yes getting rid of that blank in the speedo reduces one press. I want to see more data if possible not less, so that blank line is useless for me.
When I open the door it's always because I'm leaving the car, and I want everything off. When I park in my garage I don't lock the door so I really want it off even without locking the door. All other cars are like this. Mini is the first car that wants me to press the ignition twice to turn off on default settings. So yeah I really like the all-off feature when opening the door coded.
Old May 18, 2017 | 05:40 PM
VelvetFoot's Avatar
VelvetFoot
Did the blank line and it works great.
Turned out the door open/aux elect off was already aktiv! I think I must've opened the door before turning it off. If you turn it off first, foot on brake or not, and then open the door, things shut off. Also, if it's shut off, and the passenger opens the door, it stays on, and when the driver then opens the door, it shuts down.
