Lights?!?!?!
Old Apr 3, 2017 | 01:08 PM
mackmini's Avatar
mackmini
Lights?!?!?!
Woke up this morning with multiple lights out...
2009 Mini Cooper S R56 - N14
Front drivers Headlight
Front passenger Fog light
Passenger Side Blinker
Rear passenger side blinker light
Rear Passenger side Fog light
This cant be a coincidence....
Any ideas on whats going on? What I should do?
Old Apr 3, 2017 | 06:44 PM
AZdsrt's Avatar
AZdsrt
How old is the battery? A marginal battery on these cars cause all kinds of weird electric problem..
Old Apr 4, 2017 | 05:19 AM
mackmini's Avatar
mackmini
New owner of the car - has 80km on it.....Guess I can check the battery, Thanks
Old Apr 4, 2017 | 09:13 AM
mackmini's Avatar
mackmini
So with the rain im getting today I notice i have a leak pouring down passed my hood release and around the FRM......
I looked at the connection on the FRM and there is signs of corrosion - im sure this is causing my lighting issues......Can this be cleaned?
What process should i start now?
Old Apr 4, 2017 | 09:51 AM
MiniToBe's Avatar
MiniToBe
You can use electronic cleaner spray can. while the module is out, take a look at the circuit board.
finally the FWM is actually called FRM.
Old Apr 4, 2017 | 11:04 AM
mackmini's Avatar
mackmini
**Edited** - Thanks
I will give that a shot - hopefully works as I hear they're quite expensive
Old Apr 4, 2017 | 11:11 AM
MiniToBe's Avatar
MiniToBe
The good news is they are somewhat plug and play. you can buy a used one with similar part number and it will work fine.
to take it a step further, you will need WinKfp and NCS expert to code the VIN and program the options into the "new" used module
