How To Spare Tire Install with Storage Package
Old Mar 24, 2017 | 09:12 AM
gearhead60's Avatar
gearhead60
From: Manassas, VA where the Civil War resides.....
I ordered my 2017 ALL4 Clubman S without the spare tire package. I've never not had a spare in my car. I regreted not ordering it as it also included the tools and jack. For $100, it would have been worth the cost. Now I find myself putting the pieces together to have a spare in my car. After much research and discussion, I ordered the tire and wheel assembly from Detroit Tuned http://www.detroittuned.com/mini-coo...ire-f54-5-lug/. I could have ordered and assembled it separately, but in the end, it was about the same price either way.
I assumed that it would fit without a hitch under the floor in the storage area in the boot area.
As part of the options I ordered, it has what is called the "Storage Package", which included in the cargo area compartment liners, a multi-position floor, 12V power socket, and tie-down brackets. What is not apparent, until you get the spare tire, is that it will not fit under the floor easily as outfitted from the factory. Several things have to happen to get it to slip in without forcing it in....
Tire installed without cargo floor.
It should be noted, that in order for the spare to be placed in this area, the floor must be removed completely. Once the floor is removed, the spare can be placed in the storage area. However, it will not lay flat easily without some cutting/trimming of the compartment liner at the far back of the storage area. This liner piece does not conform completely to the back of the compartment, which does not allow for the tire to fit underneath the threshold area without forcing it.
Liner after trimming. This piece fits under the threshold to the boot. In this photo it is upside down from how it is actually installed. Sorry, but forgot to get pic before the cutting began.....
Removal of the liner piece is relatively simple. First, the floor bottom floor liner piece needs to be lifted out, then 4 push-in fasteners must be removed. The piece can then be unhooked from the adjacent liner pieces and lifted out. I roughly approximated the space needed for the tire to fit and cut it out. Here is it fitted back in.....
Here's a pic with the tire installed, looking to the back of the boot. The trimmed area is completely hidden by the tire:
Tire installed with cargo floor half open:
This fitting took me around 45 minutes and was not really difficult. Last picture is with the "Fitted Luggage Compartment Mat" http://www.realoem.com/bmw/enUS/show...diagId=03_1494.
I also considered getting the tool tray, hold down hardware, and cover http://www.realoem.com/bmw/enUS/show...diagId=71_0900, but was told that it was a waste of money. I was concerned with not having a hold down for the tire, particularly as a safety issue in the event of an accident and the tire becoming a flying missile. But after installing the tire, it's clear that it is not necessary. The tire is well wedged in place and will not move from it's position without the floor being completely removed.
Old Feb 29, 2020 | 11:37 PM
3Pedal's Avatar
3Pedal
Thanks for this write-up, very helpful, I just got my Clubman last week and the first thing I wanted to do is add the Spare.
The only thing I did differently is used the mounting bolt to hold it in. I ordered the whole kit from DetroitTuned, spare, lug wrench, jack.and cover
First step was to measure where the threaded hole is in the floor and then measure this on the carpeted floor and drill the hole
Then I could line up the center of the spare with the hole and see where I needed to trim, probably trimmed a little too much, but this part doesn't show at all once it's back in
Now the Spare fits perfect, here's the whole kit
and the cover with the threaded bolt holding it in
I really like the Detroit Tuned F54 Clubman Jack, it has the head that fits right into the jack notch on the chassis, feels very secure
https://www.detroittuned.com/mini-clubman-f54-jack/
Mine came with the 19" wheels and not many All-Season options for it, as you can see in the pic the previous owner put the crazy expensive Bridgestone Protenza S001 RunFlats on it, I may keep these for a while, but eventually will get the non runflat Michelin Pilot A/S 3+
While I was in the Mini modding mode, I also added a Bracketeer Fire Extinguisher bracket, the seat rails on the MINI are perfect for this bracket, won't work on my other car
kazyn
Oct 25, 2019 02:34 PM
Mrdi
Feb 18, 2016 11:10 AM
Slave to Felines
Nov 29, 2012 03:57 PM
Tallman
Jul 29, 2011 12:31 AM
