Suspension R53 15x8 +25, do I need spacers? Tire suggestions?
Old Mar 16, 2017 | 01:39 AM
mish's Avatar
mish
I have an 05 r53.
mods:
megan racing euro coil overs with front camber mounts
front and rear adjustable swaybar endlinks
rear adjustable lower control arm
I have a set of enkei compe wheels I'm getting ready to put on. They are 15x8 with 25 offset. Would I need front/rear spacers? If so, what size? Any tire size suggestions? Car is a daily.
Old Mar 16, 2017 | 04:46 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
I run KW V3 with swift springs + helpers. 949racing 15x8 with 225 re71r tires with +35 offset and I had to run a 10mm up front to clear the coilover springs and 5mm in the rear to clear the trailing arm.
I could remove the helpers and fit them up front, and the rear technically fit without the 5mm spacer but it's very very very close
Old Mar 16, 2017 | 09:12 PM
mish's Avatar
mish
10mm in the front, wow. I would have though 35 offset would fit better than my 25. I should have just gotten the 38 offset. How low are you?
Old Mar 17, 2017 | 03:40 AM
MrBlah's Avatar
MrBlah
I drag all over but it's as high as I can go, 15" tires put you pretty low
