I wanted to pass on that after a few days using the CravenSpeed Gemini Phone Mount; I can recommend it.
Places the phone at the right height as to not obstruct the window and only took me about 5 min to install, once I found the right size Torx head drive.
Two Torx screws to remove the Tach/Spedo and then mount goes on back of that with the screws they provide (3). The arm sticking up pivots, the phone ended up just above the vent so it doesn't block that either.
Here it is before I put the clip on it that holds the phone.
