FS:: Wilwood Brake Kit and other brake parts
Old Feb 16, 2017 | 09:29 AM
jnathan68's Avatar
jnathan68
Category: Brakes
Price: $550
Part fits (you may select multiples): R50, R52, R53, R55, R56, R57, R58
Location (Region): SoCal
Item Condition: Brand New
I have the following brake parts for sale with pics at the bottom of the listing
1) SOLLLDDDDDD Brand new Wilwood TCE DP6 brake kit designed to be used with 294 mm stock Mini Cooper rotors. This kit was put together quite a while ago by Todd at TCE and then was a display model in another shop. Includes silver Wilwood DP6 calipers, BP10 street brake pads, stainless steel brake lines, caliper brackets, mounting hardware and instructions. Everything is new however there is light scuffing on the calipers (most should rub out but please be aware they are not perfect). Note - the instructions say you will need to do a touch of grinding to the stock mounting area and they explain how/where. Great kit for giving your Mini Cooper a fresh look, better braking performance, and stock wheel clearance. This kit will fit
R50, R52, and R53 as long as you upgrade to 294 mm rotors
R52 S and R3 S cars as long as you upgrade to 294 mm rotors
R55, R56, R57 and R58 as long as you upgrade to 294 mm rotors
R53 JCW and R52 JCW (already have 294 mm rotors)
R55 S, R56 S, R57 S and R58 S (already have 294 mm rotors) SOLLLDDDDDD
2) Wilwood Rotor Hats - These are used and were on a custom brake kit that was on my Mini when I bought it and were used with 12.88 rotors with the standard 12 bolt mounting pattern. They have some scrapes but no cracks and no other issues. Great for putting together a second set of rotors if you already have a Wilwood kit.
$125 for both shipped anywhere in the U.S.
3) Carbon Fiber Brake Backing Plates - These are used and were on a custom brake kit that was on my Mini when I bought it. Not sure who made them but they are light and seem pretty well made (have air scoop even built in). These were on a car with 12.88" rotors. They show some wear but are not cracked and all mounting holes in good shape.
$85 for both shipped in the lower 48 states.
Old Feb 16, 2017 | 09:37 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
Did you run these? Any issues with pedal pressure/master cylinder sizing? also do you know what part number those pads are? I was gonna check to see how much track pads cost for them
Old Feb 16, 2017 | 09:48 AM
jnathan68's Avatar
jnathan68
No, I didn't run these since there was already a big brake kit on my car. Was planning at some point to swap to these but never did and my Mini has been sold. These calipers, with their corresponding piston size, were chosen specifically for the Mini so will work properly with stock master cylinder.
For the Pads, here are the Wilwood part numbers and compounds
A: 15A-10724K
B: 15B-10725K
H: 15H-10726K
BP-10: 150-10006K
BP-20: 150-10007K
Old Feb 16, 2017 | 09:28 PM
luckymini28's Avatar
luckymini28
Will the Wilwood caliper work with a Wilwood rotor and hat combo or only with the 294mm factory rotor? Also will this work in a 16" wheel?
