Drivetrain Inlet Options for Upgraded Turbos
Old Feb 8, 2017 | 03:14 PM
JValenzSD's Avatar
JValenzSD
Those of you with upgraded turbos feel free to chime in.
I'm in the process of upgrading my turbo to a JMTurbo Super 42, and I noticed the connection on the turbo inlet on my factory turbo is a lot smaller than the S42's inlet by a lot. I spoke with Arric from JMTurbo Coopers and he mentioned that the inlet has an outer diameter of 2"
Link to my turbo: http://jmtcperformance.com/s42-turbo...ugeot-rcz-200/
I have a K&N Typhoon CAI and its a direct fit onto the factory turbo inlet. The materiel is some kind of hard rubber that is prone to cracking when flexed too much, unlike silicone.
Are there any manufacturer's out there that carry a silicone turbo inlet pipe that would fit? I called Forge but their silicone intake tubes are a direct fit to factory turbos and will not fit an upgraded turbo inlet.
Old Feb 9, 2017 | 11:55 AM
oldbrokenwind's Avatar
oldbrokenwind
I'm surprised that your turbo supplier doesn't have the proper fittings to go with the turbo. My Garrett has a 3" inlet and I used a silicon elbow connected to a tee (for the PCV hose) then to a "sawed off" K & N Typhoon system. Lotsa custom work, not real pretty, but very functional.
For silicon hose fittings, look at ---
http://www.turbohoses.com/siliconehose.htm
http://www.atpturbo.com/mm5/
http://www.siliconeintakes.com/?osCs...f087b42c3a13e8
There's probably others, but these should get you started --- if Arric can't do anything for you.
Old Feb 9, 2017 | 12:25 PM
JValenzSD's Avatar
JValenzSD
Thanks for replying to my post. They are unfortunately on back order. I couldn't wait for the part so I'll be installing it before it arrives. Looks like I'll have to do a similar setup. Hows that Garret? Is it the GT28?
Old Feb 9, 2017 | 04:38 PM
oldbrokenwind
If Arric can get the correct part, just back-ordered, you might want to consider waiting for it --- these elbows, couplings, tees, and clamps can get pretty expensive. Plus, after "adjusting" the Typhoon, you might not be able to replace the fittings with the correct part at some later date. Give it some thought before committing to a "patch". Maybe check with some of our on-line vendors to see if they have the right-size elbow with tee.
A big Garrett has pros and cons. For me, the pros won, and I replaced my worn-out GT28RS with the GTX2860R. Then I proceeded to blow the engine. A long build journal is located here (no pics) --- https://www.northamericanmotoring.co...lta-stuff.html Disaster is described here --- https://www.northamericanmotoring.co...e-deadest.html Rebuild is in-process and posted here --- https://www.northamericanmotoring.co...s-phoenix.html
Old Feb 9, 2017 | 05:16 PM
JValenzSD's Avatar
JValenzSD
All good advice. I read your posts, much respect!!! I have a spare N14 that will undergo a full rebuild, not a extensive as yours, but close to it.
Old Jul 2, 2018 | 12:52 PM
bugeye1031's Avatar
bugeye1031
Moderator
How did your build go? I'll be installing an S42 along with my K&N Typhoon in about two weeks. Arric sent the silicone inlet hose, but the inside diameter doesn't seem just right compared to the Typhoon outside diameter.....is there a trick?
