Help adjusting height of driver's window
Old Feb 5, 2017 | 07:54 PM
idickers's Avatar
idickers
I just replaced the lock actuator in the driver's side door of our 2009 Clubman S, using the Bentley manual for guidance. The good news is that the door now opens and closes as it should, but while the glass travels up and down, it does not go high enough at the rear of the glass, at the end nearest the B-Pillar.
Bentley discusses adjusting the travel height, which sounds like what I need to do. The problem is that when I pull the plugs out of the bottom of the door, I see what looks like two torx bolts, one accessible and one inaccessible at right angle to the hole in the door. The problem is the view into the door doesn't look like the picture in Bentley.
Can someone tell me if one of these control travel height? I think one of the two is also supposed to control pressure of the glass on the seal, but the view into
