Problem opening the glass door does not come down
Hello, all the minis bring that way when you open the door the glass goes back a little so as not to leave and when you close the glass goes up that little that was missing my glass of the car on the driver's side is doing very little that this retreat a lot I can not even break the glass, have you ever had this problem?
Johnny, please don't take this the wrong way, but the way your question is worded may leave some wondering exactly what the problem is. I'm sure people want to help, and would if we could understand your question. Maybe get some help with the grammar? Just trying to help.
You could try resetting the window.
With the engine running and the door open, lower the window all the way then raise it and keep holding the "up" button for about 15 seconds after the window stops.
2. Start car.
3. Press window button down and hold for 15 seconds after windows stops going down.
4. Press and button up and hold for 15 seconds after the window is all the way up.
5. Repeat steps 3 and 4.
6. This resets the limit adjustments and it should now work.
7. Turn engine off and open door.
Did it drop down about 1/4 inch?
I seem to have to do this on a regular basis on my car especially in colder months if there has bee some ice on the windows.
