Boost your performance with Dinan Free Flow Axle-Back Exhaust System
Nothing will help you to unleash the full potential of your Mini Cooper better than performance exhausts developed and engineered by Dinan. Their free flow axle back exhaust system will provide you with maximum power and torque gains. All systems are manufactured from 100% premium quality 304 stainless steel for the best corrosion resistance. The installation process is straight-forward and requires usage of the factory brackets and hangers.
* click on the pictures below to find prices and other necessary details on this system at CARiD;
Dinan® - Free Flow™ 304 SS Axle-Back Exhaust System with Twin Tips at CARiD
Notes:
Fits: 2016 Mini Cooper S Hatchback 2 Doors F56 Body Code;
Max Gains: +4 HP @ 5000 RPM, +4 FT-LB @ 5000 RPM. 7 pound weight savings over stock.
Exhaust Inlet Connection Type: Bolt-On.
Exhaust Pipe Material: 304 SS.
Exhaust Type: Axle-Back.
Main Piping Diameter: 2.5".
Muffler Quantity: 1.
Tip Finish: Black Ceramic Coated.
Tip Material: Stainless Steel.
Tip Outlet Diameter: 3.5".
Tip Shape: Round.
Includes: Twin 90mm (3.5") stainless steel black ceramic coated and laser engraved exhaust tips, mounting hardware.
If you are planning to start your next project build, consider performance-tuned Free Flow Exhaust System by Dinan as your starting point.
Notes:
Tip Shape: Round.
