DME Question
Old Jan 19, 2017 | 06:32 PM
timthe2lman's Avatar
timthe2lman
Question DME Question
Can someone tell me if the DME is engine specific? I have a Countryman S but I have access to a DME from a Base model. Will it work or do I need one for an S model specifically? Thanks!
Old Jan 21, 2017 | 08:52 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
NO, the DME is coded and VIN specific to each car. So if you need a DME you need to order a new one with your VIN. Can't make a used one work as the codes won't match to the rest of the car and won't start
Old Jan 22, 2017 | 07:57 AM
timthe2lman
Thanks, WMW for the info. Are all of the modules in the car coded to match each other? In other words, can any of the computers be replaced without being coded to match? I suspect that my JBE might not be original to the car. I'm not finding a way to verify that either way. I do know the DME's label matches the VIN of the car.Unfortunately, I can't communicate with it or any other PT-Can components. JBE flags a C90B PT Can comm fault.
Old Jan 22, 2017 | 07:44 PM
WayMotorWorks
Vendor
Yes pretty much all the modules are coded to the car. Some can be recoded to work in a different car, but not always. Often if you use a module coded to another car you can loose features or functions. So make sure they car coded to the car before chasing any other problems
Old Jan 23, 2017 | 02:56 PM
timthe2lman
Do you know how I would go about checking the coding on the JBE?
Old Jan 29, 2017 | 11:38 AM
WayMotorWorks
Vendor
You would need a shop that can code modules. Then install the new one and code it. No way for a DIY on coding at home.
