R50/53 Death rattle
Old Jan 18, 2017 | 06:36 PM
Setflyn41's Avatar
Setflyn41
Death rattle
I changed my chain tensioner today to try and get rid of a slight noise when I started the car cold, after changing it I now have the death rattle all the time which I didn't have before I'm hoping I didn't ruin my guides somehow but I tried throwing the old tensioner back in and got the same result, I suspect the tensioner isn't popping out anyone know why that might be?
Old Jan 19, 2017 | 04:48 AM
IQRaceworks's Avatar
IQRaceworks
What "death rattle" are you talking about? Can you post of a video? When the engine is idling does it make the noise? If so, can you watch the tensioner and see if it's bouncing around on the belt?
Are you sure it's the tensioner and not something else like the throw out bearing on the clutch? Those will make a rattling noise if they are wearing out...but usually if you push it the clutch it gets quiet again.
Old Jan 19, 2017 | 05:06 AM
Setflyn41's Avatar
Setflyn41
It's definitely not the throwout bearing I changed the clutch and throwout less than 1000 miles ago
https://youtu.be/7JZNG1uVVo4
It sounds exactly like that
The chain tensioner doesn't seem to be putting tension on the chain at all it seems stuck like it won't pop out
Old Jan 19, 2017 | 05:16 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
they are machined really tight, I had this problem with one of mine. Did you buy genuine or oem?
one of my originals is stuck collapsed I cannot get it apart now, was gonna check for wear in it.
Old Jan 19, 2017 | 05:19 AM
Setflyn41's Avatar
Setflyn41
It's not genuine I got it from autozone
Old Jan 19, 2017 | 12:09 PM
BlwnAway's Avatar
BlwnAway
Yup, it sounds like it's just stuck closed, I have been able to pop them open by applying pressure to the center with a socket extension while on a hard flat surface, to fully collapse it, but it did take a few tries.
