R60 The gremlins hate my horn
Sooo, the fuse for my horn burnt out and I bought a 20 amp fuse from Advanced Auto Parts and replaced it. Later the same day, after using the horn a couple of times it burnt out again. I attributed it to, possibly, a faulty fuse (I've come across faulty fuses in the Jeep). I bought a different brand 20 amp fuse from Pep Boys and it lasted 3 days and burnt out again.
Has anyone come across anything like this?
No Codes
No Codes
Yes, it's the stock horn. That's just it, It's not showing that it is drawing more than 20 amps
ok, try and disconnect one horn and see if the fuse blows gain, if not, reconnect and disconnect the other horn and see if that blow the horn. if in both instances you are blowing the fuses. disconnect all horns and see if that blows the fuse (and yes, pretend that you are honking the horn like you would normally do) and see what happens
