R50/53 Automatic trans help, need advice!
Old Jan 15, 2017 | 01:14 PM
speedman's Avatar
speedman
My 2005 MCS has the 6 speed automatic and yesterday the car shifted from 3 to 4 and nothing by motor revs. Pulled over and turn the car off and when I restarted the car flashed the EP code. The car would not go in any gear but when I press the gas pedal the car would move slowly. The day the car would drive in 1,2&3 gears and then 4th and nothing by motor revs. I disconnected the battery for 12 hrs and when I reconnected it the EP code was still there. I still only have 3 forward gears but the car will go to about 50 mph. If I reset the computer with a ode code reader is there any chance the transmission will go back to normal or does it need a new valve body. I need advise
Old Jan 15, 2017 | 07:53 PM
MiniMello's Avatar
MiniMello
Sounds like it is eating the clutch packs was it run low on fluid?
Old Jan 15, 2017 | 10:44 PM
Mini Mania's Avatar
Definitely check the fluid level and, if possible, the linkage. Let us know what you find out.
Old Jan 16, 2017 | 05:14 AM
speedman's Avatar
speedman
I have changed the fluid three times per the Pelican Parts Tech Article in the last six months. I have not seen any leaking so I feel like the fluid level is OK. If the clutch paks are bad I don't think I would 1 through 3 gears. It feels like the 4 gear valave is not working.
Old Jan 16, 2017 | 01:50 PM
speedman's Avatar
speedman
I need some of the auto trans guys here to give me an idea of what to do.
